kingfisher23 Posted April 23, 2014 Report Posted April 23, 2014 Hi guys, I have a Kenwood eXcelon KAC-X401M and just here recently my subs quit working. I looked at the amp and the blue light on it will stay on for about 10 seconds then flick off and then back on. Do you all have any advice on what might be causing the amp to kick on and off? I have checked all wiring and it is good
hazestorm23 Posted April 23, 2014 Report Posted April 23, 2014 Did you check amp fuses and all ? Opened it up and noticed anything out of the ordinary
Guest Posted April 23, 2014 Report Posted April 23, 2014 unplug woofers from amp. see if it still shuts off. if it doesn't shut off with no woofers hooked up, then one of the voice coils is bad.
White Lightning Posted April 23, 2014 Report Posted April 23, 2014 double check all of your grounds Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
kingfisher23 Posted April 23, 2014 Author Report Posted April 23, 2014 double check all of your grounds Did you check amp fuses and all ? Opened it up and noticed anything out of the ordinary I check all wires and they are good. I did check the fuses and none of them were blown. Any other suggestions?
kingfisher23 Posted April 23, 2014 Author Report Posted April 23, 2014 unplug woofers from amp. see if it still shuts off. if it doesn't shut off with no woofers hooked up, then one of the voice coils is bad. I didn't have subs plugged in when I was checking amp
PolishThunder Posted April 23, 2014 Report Posted April 23, 2014 Sounds like its going into protect mode. That usually means something is shorting out somewhere or a bad voice coil. If it doesn't go into protect (flashing/blinking light) without the subs wired something is shorting with the subs try one at a time to see which one it is. Otherwise it could be something with power/ground or damage to the amp. Did you get in any accidents or go over a large bump before this happened?
kingfisher23 Posted April 23, 2014 Author Report Posted April 23, 2014 Sounds like its going into protect mode. That usually means something is shorting out somewhere or a bad voice coil. If it doesn't go into protect (flashing/blinking light) without the subs wired something is shorting with the subs try one at a time to see which one it is. Otherwise it could be something with power/ground or damage to the amp. Did you get in any accidents or go over a large bump before this happened? Have not been in an accident. I checked wires and they looked okay. I did smell a funny almost burning like smell about a month ago and subs quit working not long after that
rockFord_Expedition Posted April 23, 2014 Report Posted April 23, 2014 Get a DMM, plug the black wire to your amp - and the red wire to the amp + record voltage. Move red wire to amp turn on lead, record voltage. What are your findings? Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
PolishThunder Posted April 24, 2014 Report Posted April 24, 2014 Hmm, something could have shorted when it started to smell like that, and now its going into protect mode. If you don't have a warranty maybe open it up and see if anything looks burnt or if any leads are loose or could be shorting. The burning sounds like it would be the subs not the amp but it could be both. Using a DMM to check stuff is a good idea too.
