gally Posted April 24, 2014 Report Posted April 24, 2014 So i built a couple of boxes for my GZNW 15SPL---it turned out that it did not play as i wanted...sounds horrible... subs specs :Ground Zero Nuclear 15SPL (the yellow sub) Model GZNW 15SPL Diameter 38 cm / 15" Mounting diameter 360 mm / 14.3" Mounting depth 255 mm / 10.04" Voice coil 75 mm Flachdraht / 3" Flat wire Cone Paper-glassiber-kevlar Power Handling 6500 W SPL Power Impedance 2 x 1 Ohm SPL 91,7 dB Xmax 50 mm / 2" Fs 32.3 Hz Qts 0.42 Vas 65 L / 2.3 cu.ft ...................................................................................................................................................................................................................... what i want is if someone can help me with a box design i speciffically want a Sub up and port bwlow(down) on the right side max dimension are: wide -- 80cm high -- 48cm deep -- 44cm tuned at about 30-33hz thanks in advance gonna be powered by 2 dd m1b wired both at 2ohm 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
john253a Posted April 24, 2014 Report Posted April 24, 2014 Post the specs of what u built What car Amp power You know more info
gally Posted April 24, 2014 Author Report Posted April 24, 2014 Post the specs of what u built What car Amp power You know more info its a hatchback an opel corsa c amp power would be 2 dd m1bs both wired at 2ohm dont have any more info as im writing you guys from a tablet my pc is gone for a couple fof days as it burned its motherboard 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
gally Posted April 25, 2014 Author Report Posted April 25, 2014 anyone? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Joe X Posted April 25, 2014 Report Posted April 25, 2014 Post the box you did, would like to see what made it going so wrong.
gally Posted April 27, 2014 Author Report Posted April 27, 2014 ok sorry for the late reply...found the difference...box was way off i i was using some shitty glue...and the L ported side came off and the wood panel ond the bottom came loose so i built another box tuned to 34 and it sound way different..sub is also inverted and so far it plays....down to 26 and get louder on higher notes(but not always) need to post a vid in a while i also reinforced the box with sillicone inside and did not get the 45s in the corners...this time.... 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
