Alternator issue?
Hello Bassheads,
I purchased a Mechman 320A H.O. alternator back on 2010. I installed it and everything was OK.
But as time went by I noticed a great drop in performance.
At first, I had more "stable" currents and restoration.
So I took a clampmeter and tried to measure the alt. I measured all 3 wires attached to it while I was testing in tones in order to generate full load.
So I added all the measurments and got about 200A with a voltage drop to 11.7V
Any idea on what is wrong so I can take it off and perform a service on it?
2007 Peugeot 206 1400cc 75hp
Head Unit: Pioneer DEH 80PRS
Speakers+Tweeters Amplifier: 2 x Hifonics Colossus Generation X3
Bass Amplifiers: 2 x Taramps HD8000 (quadraple copper terminals by Toolmaker Metalworkz)
Tweeters: 6 x Digital Designs VO-B2 + 4 x Beyma CP21/f
Midrange Speakers: 20 x 8" Beyma 8M100 Nd
Subwoofers: 2 x Digital Designs 9918 walled
Alternators: Mechman 320A universal + Bosch 260A
RCA: Dragster OFC twisted triple shielded
Wires: 0gauge big3 upgrade with SP audio, Currents with SP audio, Grounds with Rockford Fosgate
Batteries: 980AH of power with copper rails.
Alarm: Python 5303P
So far 161.4 dB with a Cadence 9kW @ Salamina 2014.
Nobody?
Alarm: Python 5303P
Bumping your own thread in the same day you post doesn't help.
you got the alt from mechman, contact them about it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
you got the amp from mechman, contact them about it.
you got a chuckle out of me lol
Did you talk to mechman already?
97 Suburban
8 custom PSI Platform 3 18's
I wasn't really bumping. I just thought that someone may already have been affected by a similar problem and could tell me approximately what to check on it.
Most US H.O. alts have the same architecture, but again, I guess I am the only one facing this problem...
No not really. Actually I was expecting some help from other members. But I guess you are right. Should contact Mechman.
Alarm: Python 5303P
So sorry for being in the wrong section. To avoid duplicates, could a mod move it there?
Thank you in advance.
Alarm: Python 5303P
Well if you want my guess I'd say the voltage regulator is going out since you mentioned low amperage at 11.7V but I'm nobody and that's just a guess...I'm sure mechman will take good care of you.
97 Suburban
I was actually planning on changing all the diodes and brushes...... The voltage regulator is external and consists of a diode and a variable resistance. To be honest, I really don't have a clue on what happens inside this architecture's alt.
Alarm: Python 5303P
Fixed my post.. I swear it said alt. Sometime be edited it. Lol
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 8265 Guests (See full list)
