Help with a complicated enclosure (Wedge with FI BL's)
KWP123
Size of sub does not determine how well it will play different freq.
box design is a huge part n that. Hence why he is saying 2 12s in a box of adequate volume will be better. Not just louder but could be able to play the same songs with more force.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Don't sacrifice port area. It can create port noise but on the worse side you could end up with a less then optimized sound quality/freq range.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I thank EVERYBODY FOR ALL OF THE HELP!!!! This is what I have so far
First the tuning calculations:
And now my very VERY rough SketchUp (first time ever using the program). I know that I didn't complete the port length... This is getting very intricate, so I want to make sure I am going down the right path first. ALSO for the port length to be 35" I will have to bend up the vertical Back Face AND also bend again to on the Top Face... is this feasible or am I waisting my time with a port that long???
Here is the completed port. after crunching the number I will only be able to pull off 33.5625 (9/16) port length. (Unless somebody tells me it is ok for me to continue my port along the Top Face. So after puting that into the calculator I am now tuned to 34.68Hz.
The latest tuning calculations
And the finished box based off of the tuning calculator
So Is this possible???? or am i still to small?
  • Who's Online   0 Members, 0 Anonymous, 3493 Guests (See full list)
