Thewes Posted March 18, 2008 Author Report Posted March 18, 2008 With how you're wiring it up, (master and slaving the amps) IS strapping the amps and you didn't complete it.Now, if you run an RCA cable from the RCA output (not BR out) on your first amp to the RCA input on your second amp, that won't be strapping the two amps but you'll have to match the gains. So the reason my subs are playing louder on one amp then two is because I didn't master/slave them correctly? Wouldn't as long as the amps receiving a signal from the other amp it would be louder than just 1 .5 ohm sundown 1500? I'm not sure but Ill try to strap them and see if that works out. Quote
EricM9104 Posted March 19, 2008 Report Posted March 19, 2008 So the reason my subs are playing louder on one amp then two is because I didn't master/slave them correctly? Wouldn't as long as the amps receiving a signal from the other amp it would be louder than just 1 .5 ohm sundown 1500? I'm not sure but Ill try to strap them and see if that works out. One of your subs wouldn't play correctly (with the two sundown's) thus causing wave cancellation and it seems less louder. Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Thewes Posted March 19, 2008 Author Report Posted March 19, 2008 One of your subs wouldn't play correctly (with the two sundown's) thus causing wave cancellation and it seems less louder. All right I figured it was cancellation of some sort due to my electrical being pretty stable. Some good news is, I strapped them like shown on the sundown website, letting the master take all the positive connections and the slave getting all the negatives. Needless to say its fucking loud, only problem now is it goes into protect on the lows because my lack of electrical, and I have a nice little engine noise going (bad rcas? I paid 40 bucks for them? Knuknonceptz?) Anyways, appreciate all your help. It BUMPS when its on haha. Quote
banginAltima Posted March 19, 2008 Report Posted March 19, 2008 For whatever reason, strapped sundowns seem to have engine noise. happened in my car and Derrick's Yuk... Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
banginAltima Posted March 19, 2008 Report Posted March 19, 2008 also, it could be going into protect because your ohms are too low. Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Thewes Posted March 19, 2008 Author Report Posted March 19, 2008 also, it could be going into protect because your ohms are too low. I have dual 2's, isnt it at 1 ohm? Quote
Stephen Posted March 19, 2008 Report Posted March 19, 2008 I have dual 2's, isnt it at 1 ohm? dual 2's would wire to a final load of 2ohms, split between 2 amps they are seeing 1 ohm each Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Thewes Posted March 19, 2008 Author Report Posted March 19, 2008 dual 2's would wire to a final load of 2ohms, split between 2 amps they are seeing 1 ohm each yeah that should be fine on those amps strapped. Its not the ohm load, its just my shitty electrical. Quote
