Andrew Posted November 23, 2006 Report Posted November 23, 2006 I searched the forum and couldn't find anything on this so I decided to start my own. Meade has his modded rockford amps... Just wondering, what was the original ratings on those and the ratings after being modded? I want to do that to my amp and wanted to know who will do a good job with it, any referencees for this type of work? By the way my amp is a Memphis MCD1000 - 1100 x 1 at 1ohm. Thanks, Andrew New project in the works
AI James Posted November 24, 2006 Report Posted November 24, 2006 since you searched youd know where to put the topic then i would assume
going deaf Posted November 24, 2006 Report Posted November 24, 2006 "modding" an amplifier doesn't necessarally give you more power over the factory ratings, rather it lets you run the amp below rated ohm recommendations with more stability... noobs kthnxbi
RichardXTC Posted November 24, 2006 Report Posted November 24, 2006 is it costly? 2 X 15inch XTB subs1 X Solar Audio 5000dVids:<a href="http://"http://www.realmofexcursion.com/videos/XTC...dio/xtb15.1.wmv"" target="_blank">http://www.realmofexcursion.com/videos/XTC...xtb15.1.wmv</a><a href="http://"http://www.realmofexcursion.com/videos/XTC...dio/xtb15.2.wmv"" target="_blank">http://www.realmofexcursion.com/videos/XTC...xtb15.2.wmv</a>
ChevyBoy Posted November 25, 2006 Report Posted November 25, 2006 "modding" an amplifier doesn't necessarally give you more power over the factory ratings, rather it lets you run the amp below rated ohm recommendations with more stability... running a lower ohm gives u more power. so technically, yes.
