2000 Mountaineer Build (from ramming to slamming Part II)(Slowest 15k build)(More limitless goodness)
Then to make things worse my radiator went out and started leaking antifreeze everywhere. So we're replaced the radiator, upper hose, lower hose, and thermostat. Fixed all that and was going to do spark plugs and wires and this happened
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
spark plug snaped off in the head!!! fk my life! so googled it and started searching on forums and what have you of what to do and came across a article that said he got it out with a easy out #5. so sprayed the crap out of it with pb blaster and let it sit overnight and next day after going to ford dealership and talking to mechanics there. pb blasted it again and heated it up with a map gas torch for 20 or so minutes. put together the contraption of easy out #5 a socket and a extension. with a shit ton of torque and luck poped it loose and it came out. was so happy! this is my daily driver and need it to get to work and what have you.
will post more pics and progress tommrow
Good job on getting the plug out. That could have been bad.
I looked for you at slam but never saw your truck. But on the other hand I've watched vids of stuff I never saw either. Layout was a little weird this year.
I was there should of try to compete but didn't would of liked to of gotten it metered for the hell of it was walking all over the place checking out people's systems and getting demos from as many people as I could have like 300 pics or so of slam. Will have to get some people's numbers so I can meet up with some people.
Finally fixed all my leds had a bad solder joint on one of the leds resodered it and worked like a champ also cleaned up wires better to try and cut down alt wine. And recut threaded rod that I cut to short the first time. to Fix my screwup. Also re grounded hu to battery for alt wine. Helped a lot. That's pretty much where I am on the build will hopefully have time to replace my bass knob with the lc-1 this weekend.
Basshead problems
Broke the metal on the mirror never have had this happen before usually glue joint on glass breaks.
  • Who's Online   0 Members, 0 Anonymous, 2301 Guests (See full list)
