2000 Mountaineer Build (from ramming to slamming Part II)(Slowest 15k build)(More limitless goodness)
Still have to tweak take and eq a little more but sounds a whole lot better
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Needs to do more inside the door but got majority of passenger door deadened
Db speaker box what size and type of weather stripping? Midbass on passenger side door is alot better. Have to do little more behind the speaker. Then start working on driver side door. Have another Basshead problem overhead display/ light sunroof switch broke and is now half falling down. Anyone with similar car have this problem and fix this need help. Ty
Ya fixed it with epoxy and reinforced it with some aluminum from work. Hopefully this holds up.
Damn that sucks. The one I'm building doesn't have one of those.
The weatherstripping was just the thickest foam strip they had. I think it was like an inch wide and was in a big coil. It had adhesive on one side. Just peel back the tape and apply. It is usually with the window or hvac dept. I believe it was made by frost king or something like that.
If you really wanted to go ham you could get that rubber/foam split pipe insulation and use adhesive to put that up. Im not sure how attractive that would look tho lol. These strips blend in pretty well. I don't think anyone has even noticed them.
What our u building in yours? And what year?
  • Who's Online   0 Members, 0 Anonymous, 2301 Guests (See full list)
