how do you secure your sub enclosure
I am soon getting a trailblazer and I am wanting to know how you guys make sure it doesn't move. I will soon be getting second 18 zcon. I know the enclosure will be heavy with 2 65 pound subs and 100+ pounds of wood. So i was just see what you guys use or should i not even brace it at all
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Haven't thought about those, thanks
06 monte carlo
2 12 rockford p3s
ct sounds 125.4
You can mount a 3/4 board to floor then come from inside the box to give a cleaner look also. If you are planning on removing then heavy L brackets are cool.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Bolt the box to the floor before you install the subs.
If you drill through the vehicle floor, make sure you know what is on the other side!!!
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
If your not doing carpet on your enclosure you can do carpet on just the bottom.you can't see it and the carpet on carpet friction keeps it from moving (I also have a trailblazer)
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Not sliding is great. Holding it down in a crash is better. . .
Current system:
Previous systems:
Thanks for the input guys giving me lots of great ideas
06 monte carlo
2 12 rockford p3s
ct sounds 125.4
  • Who's Online   0 Members, 0 Anonymous, 3139 Guests (See full list)
