jarball25 Posted May 13, 2014 Author Report Share Posted May 13, 2014 You ran 1.4 nominal on one amp, and then 1.4 nominal on a pair of amps? yes but 1.4 with 4 subs one amp than 1.4 with 2 subs each amp Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 13, 2014 Report Share Posted May 13, 2014 Let's think about this. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
CstrokerV Posted May 13, 2014 Report Share Posted May 13, 2014 im guessing user error or faulty amp my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
jarball25 Posted May 13, 2014 Author Report Share Posted May 13, 2014 Let's think about this. ???? Link to comment Share on other sites More sharing options...
jarball25 Posted May 13, 2014 Author Report Share Posted May 13, 2014 im guessing user error or faulty amp again this post is not solely about the amp not being the best or what amps are. however the post is for me to better understand the relationship between subwoofers resistance changes and amps ohm loads please Link to comment Share on other sites More sharing options...
CstrokerV Posted May 13, 2014 Report Share Posted May 13, 2014 4 subs at 1.4 is the same as 2 subs at 1.4 .. yes as the frequency changes so does the ohms.... usually higher then the 1.4 ohms the subs are at when there is no signal applied if the amp was 1 ohm stable it shouldn't of taken a dump at that ohms my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
Jessica Posted May 13, 2014 Report Share Posted May 13, 2014 OP, kyle is probably going to explain to you that you cant wire one amp to 1.4, and 2 amps to 1.4 with your subs. since you have 4 dual .7 ohm subs, you can wire to .7 or 2.8 on one amp but not 1.4 with 2 dual .7 ohm subs you can wire two amps to 1.4 each or .35 each think i did that right. edit: can should have been cant Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
CstrokerV Posted May 13, 2014 Report Share Posted May 13, 2014 OP, kyle is probably going to explain to you that you cant wire one amp to 1.4, and 2 amps to 1.4 with your subs. since you have 4 dual .7 ohm subs, you can wire to .7 or 2.8 on one amp but not 1.4 with 2 dual .7 ohm subs you can wire two amps to 1.4 each or .35 each think i did that right. edit: can should have been cant with 4 subs he can get a 1.4 ohm load each sub wired to 1.4 each pair wired to 2.8 then parrallel the pair to 1.4 my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 13, 2014 Report Share Posted May 13, 2014 Now do that with 2 subs to one amp. And see 1.4 Nom With .7 coils. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
