load350z Posted June 15, 2014 Author Report Posted June 15, 2014 So u suggest 12 to 15sq in of port sub? Im getting confused.. or 12 to 15in per cuft 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
timc31610 Posted June 15, 2014 Report Posted June 15, 2014 If you are doing a slot port I would recommend 80-100 cubic inches total. That comes out to 12-15 per cubic foot. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
load350z Posted June 16, 2014 Author Report Posted June 16, 2014 Ok got it.. thanks for ur replies 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
jbone 86 Posted July 22, 2014 Report Posted July 22, 2014 Can someone help me and refer me to a box builder I'm having a hard time finding a box I have a 97 aroura and the trunk is pretty big but the opening really isn't I have 2 sa 12s
timc31610 Posted July 23, 2014 Report Posted July 23, 2014 Can someone help me and refer me to a box builder I'm having a hard time finding a box I have a 97 aroura and the trunk is pretty big but the opening really isn't I have 2 sa 12 Another person's thread isn't really the place to post a question like this. Try starting your own thread and you will get more responses. You will also need to supply more information like max available space, amp you are running, what tuning you are looking for and so on. Also it is fairly hard to recommend someone without knowing where in the world you are. Welcome to the forum btw and don't forget to read the rules section. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
SlamminBeats Posted July 23, 2014 Report Posted July 23, 2014 is this going in a trunk of a sedan? I would do the 12s firing forward.
load350z Posted August 25, 2014 Author Report Posted August 25, 2014 Back on this topic again. . Would it be a considerable difference between two 12s or eight 8s on 4000w? 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
slowfkncar Posted August 25, 2014 Report Posted August 25, 2014 Back on this topic again. . Would it be a considerable difference between two 12s or eight 8s on 4000w? 8 8" would have double the cone area as two 12's. Most likely the 8's will be noticeably louder.
load350z Posted August 25, 2014 Author Report Posted August 25, 2014 Yea I figured that.. juz wanted to double check being 8s has a punchy sound and 12s has a deeper sound naturally 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
slowfkncar Posted August 25, 2014 Report Posted August 25, 2014 Yea I figured that.. juz wanted to double check being 8s has a punchy sound and 12s has a deeper sound naturally Yes,its just the general nature of sound. More diameter = easlier produced low frequencies vice versa. It all depends on the subwoofers though. An 8" with 28mm xmax will not be punchy like an Meso8/SA8 ect. If your trying to destroy lows then why not 4 12's? Slightly more cone area then 8 8's. It will also be louder then 8 8's on the same power.
