94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
Continuing on, let's clean the intake.
Not 100% sure what this piece is called, but it needed to come off.
10855044_680145732094560_502490123023551
So do all of these other sensors, and vaccum trees.
10983316_680145738761226_617136616821338
1501039_680145742094559_6159944923882409
10865896_680145838761216_872562802846856
And now for the gasket for the throttle body.
10953208_680145832094550_723440336387019
10984174_680145868761213_811671010547436
After a little wire wheel action on the air angle grinder. Good as new!
10669042_680145895427877_448128846359802
Clean up the thermostat area.
1531600_680145882094545_4726207869515605
10854378_680145925427874_402840647726531
10959960_680145948761205_956831572351519
Time to get serious! This is gross!! This is the underside which is above the valley, obviously.
10854366_680145945427872_255653568841698
Let the degreaser sit on it for a while. Rubbed it down with a wire brush to agitate the oil.
1801355_680145968761203_1570437969246965
And bam! Not bad for a first round!
10827937_680145995427867_100943981986611
Little more love on one side and the ends with the wire wheels.
10929173_680146002094533_190971648926041
And here is the finished product! Nice and clean!!
1913198_680146022094531_5916789645492085
That was it for one night. Next I have to do the top.
10974402_680146048761195_900415779780047
10636414_680146052094528_399394955979386
While she sits and soaks, I decided to utilize my time, and move onto a different project that needs to get soaking as well.
Fuel injectors!! So to do this, I bought some picks from harbor freight, although I didn't really need them but you all know what it's like to get new toys!! Got lots of those. Harbor Freight is EVIL!!!!!!!!!!! So, Picks, screwdrivers (flat and phillips head), a pair of needle nose pliers a utility knife and a #8 machine screw. I was told a #10 wood screw would work as well, however, this is what I had laying around. Oh also going to need some gloves and rags!
10960238_680146065427860_524533825895901
First cut the hat, just on the side and top if you'd like.
10953881_680146092094524_474070223649999
With the flat head screwdriver, pop the top off. It should come off pretty easily.
10927248_680146098761190_847452984304435
Then pull off the o-ring and the plastic washer. Pick isn't necessary for this, they just come off pretty easily.
10974243_680146115427855_619404547746066
on the other end, you can use the pick and pull that o-ring off, because there's a lip on the other side.
10958350_680146152094518_644624749547243
10857396_680146162094517_825280963158569
Next take your screw and phillips head screwdriver and screw it into the basket on the end with the lip. The other end is closed with 4 holes in it, so there's really only one end to choose from.
1957829_680146185427848_8594063732336905
Next, pull with your pliers and bam, it's out. You'll maybe have to wiggle it back and forth, it's a pretty tight fit.
10982570_680146198761180_750439703015146
7 more times and this is what you're left with!!
10608229_680146212094512_470829379303703
Next find a container to put them in, preferably one with a lid. I actually thought I had an 8 x 8 foil pan left over from Thanksgiving, but apparently it got used. SO, Pyrex glass pan here we come. Lined it with foil, although later on that didn't work cause I must have punctured it somehow. Line your injectors up, I did anyway to keep them in an order the way they came out.
10982646_680146238761176_510142326561916
Next you'll fill the container with this stuff. Berryman B-12 Chemtool. It's kind of nasty stuff. I got this and one more at O'reilly Autoparts.
10952868_680146258761174_130549850643143
Fill the container just over the top of the injectors. This took two of those cans above. Immediately the gunk started coming off of the outside. That's why the color is so dark. The B-12 pours out clear.
1974021_680146278761172_8337154875974395
Now, cover it with your container lid, or in my case I just covered it with foil and let it sit. You can let it sit for a day or two. I've been told not to leave them for more than 2 days. Not sure why, but part of the body is plastic and like I said, this is pretty nasty stuff. So, cover it and head back to another project.
Back to the intake. Wire wheel, wire brushes, degreaser, and a sponge and this was the end result. I'm happy.
10608229_680146305427836_375622454148675
10475968_680146318761168_878132640374742
What is this? Another new toy. WOOT! Parts washer. I put it on the workbench because the legs looked a little wobbley to me, and I quite frankly didn't have enough room to put it down anywhere.
10974532_680146328761167_314083059706972
10848867_680146358761164_452770842791067
Let's clean up these rockers and rods. I put some zipties on the ends of the rods so that i would remember which side was up. Remember these came out in order and they need to go back in same order. I didn't change the cam or the rods or rockers so they're broke in where they were. Plus this box was a bit deeper than the last box so I had to make sure they didn't drop in, lol
10974355_680146398761160_277422680017231
Just to see the difference, the clean one is on the right, and the dirty one on the left.
10985351_680146388761161_451813074107537
10872890_680146402094493_790690117902921
Made my own soaking tray. The blue one sat on brackets and the only way to drop it down into the solution was to tilt it and that caused things to move a round a bit. I didn't want that so I had this bbq grill screen I bought from Home Depot a long time ago. Couple zipties and we have a home made drop in tray.
10911441_680146452094488_484004755842848
10943692_680146462094487_274089596514149
After a night of soaking, I pulled them out and cleaned them one by one.
10955783_680146472094486_266538151563269
Just like new.
10855066_680146508761149_704721961751285
Now to address this disaster!!
10974630_680146522094481_171959896676069
10960023_680146542094479_863024944836555
This is the driver side cover. This one sat out and you can see the inside began to mildew and rust. We'll take care of that!
10947297_680146565427810_154899744882758
10633178_680146588761141_481151594625074
These will soak in here for a while.
10854908_680146595427807_219811419310637
More of the rocker arms and rods.
10959954_680146612094472_460314325713419
Putting them back into a new tray, back in order. These bad boys are ready to go back in, when it's time. But not now.
10397197_680146645427802_687793860004830
1501115_680146652094468_6021854213104463
After soaking for a few days, it's time to clean this thing up. You can see how alot of grime has raised up and is ready to get cleaned off.
10974227_680146665427800_634425639012658
Before I did that I had to take a few pics of the schematic stickers on the side.
10945840_680146692094464_112362219045155
1492668_680146695427797_8614933691464559
10915020_680146705427796_736066612160460
Now a little love with a couple of brushes, no wire wheel this time. Most of the grime is off, but this isn't going to work for me. Gonna have to get real with this thing!
10950685_680146748761125_383769872167978
So I got the wire wheels out and went to work!!
10865896_680146765427790_858474385504335
I decided that the bolts were no good. Well the bolts were ok, but the rubber washers were pretty bad, and since I'm replacing most of the bolts with ARP black bolts, I figured why not. Actually the kit I bought came with bolts for a non EFI model. I shot an email to the guys at ARP, and they said send the other ones in, and we'll exchange them straight up for the ones you need. So, I little hint to anyone doing this on an EFI, and you get the ARP accessories bolts, it does not come with these. When you order, if you order straight from ARP, ask them to swap them out there. I ordered mine from Summit Racing, so I had to email directly to ARP. But great outstanding customer service!!
Let's get back to those injectors. They've been in their bath for a couple of days now so i needed to get them out. Next order of business is to blow them out. In order to do that I have to open them up. To do this, I have a 9V battery. DO NOT USE THE 12V CAR BATTERY, IT CAN RUIN THE INJECTOR! This stuff cost me $10. A new injector costs about $30 - $50 depending on what kind you go with.
So 9V battery, alligator clips, and battery connector. Also, a new air nozzle with a rubber tip and rags.
10446302_680146785427788_851862850372755
I made a pig tail for this, using the alligator clips, some SHCA Primary Wire I had laying around (SHCA FTMFW), and the battery connector. Soldered them all together, threw some heat shrink on, and you wind up with this.
10838075_680146795427787_175377949464405
10960018_680146805427786_202607251944613
10845658_680146838761116_734047820036466
Now, let's get these babies out of the bath.
1978478_680146852094448_3795376838474104
Nice and clean
10974167_680146858761114_733581387746207
On the side of the connector housing, you'll see that one side has a +, and the other side has nothing. The + is for the positive. Here's the part number for the injector too if you're looking for a replacement.
10974431_680146872094446_573369757237057
10856689_680146902094443_335168504881074
Red to Positive
10945840_680146908761109_873003309288369
Black to negative. It should click when you connect the black. It won't like blow up in your hand or anything. Just a small click, much like a relay would sound like when activated.
1602118_680146922094441_1518659419093225
Now, take your air nozzle, hole it tight on the end where the basket was you pulled out, and blow!! I would suggest blowing into a rag or paper towel. That way you don't get chemicals on your work bench or in the air, or worse in the face. WEAR SAFETY GOGGLES!!!
10887349_680146948761105_760598197631077
Once they're all cleaned out you're ready to start rebuilding. Now, you could save yourself some hassle if you want to and send these in to be done. It costs about $17-20 per injector plus shipping. The benefit to this is, they have a special machine that tests them etc, charts flow, stuff like that. If I were going to keep this thing, I would've spent the $150 to have them do it so I knew they were going to be like new. But, I decided to do them myself instead.
Mr. Injector is a great place to go to find replacement parts. There's his card, website, phone number, no that's not OUR Bill Johnson. But his website is full of information. I'd recommend at least visiting it if your even thinking of doing this.
Got all of my parts ready.
10403901_680146955427771_596941956633849
1401998_680146968761103_3002871322611424
This is how they'll go on, in this order. Start at either end, but they go on like this.
10974511_680146995427767_283347475663425
Tap the basket in with a socket extension or something heavy enough to get it in, but not hard enough to damage it. You just are tapping it not pounding it. Make love to it, don't hump it like a hooker!!
10958006_680146998761100_848223423547821
Slide the O-Ring on and that side is done.
10960403_680147012094432_188337249141729
Next Side. Slide the plastic collar on
10952251_680147072094426_503878868961842
followed by the O-Ring.
10928840_680147065427760_647548813418780
And then the cap. Now, the cap is a little tricky because it's tight. This is where the website I mentioned above comes in very handy! They suggest heating it a little with a heat gun, and then using a socket or something solid to push down on.
10984199_680147085427758_658157366233965
A 9MM fits over the hat nice and snug. Not much movement so there's no risk in flipping it and ruining the hat and or injector.
10914934_680147155427751_442819669332194
Push down like so.
10011588_680147158761084_244405023032652
You should feel it pop into place. Check to make sure, I didn't get a picture of this, that the 4 holes are within the hole in the hat.
10974191_680147162094417_671359003431126
And you're one down, 7 more to go.
10983543_680147202094413_225548800152833
  • Who's Online   1 Member, 0 Anonymous, 1464 Guests (See full list)
