Guest Nismofreak
your going to need 2 360.2s to go 3 way active if thats what your planning on doing :(
and who cares about what amp has better crossover, you aint using the crossovers on the amp if your running active...
Thats one way to do it...Run mids off two channels, highs off the other two. You don't have to tri amp to run active.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
running mids and tweets is only 2 way... I dont think there is much point in running active if your just running mids and tweets..
mid bass
mid range
tweet
sub
ftw?
Nismo, what ever happened to the imprint that your gonna get?
Guest Nismofreak
wanna go active. This type of imprint didn't let me and cost about $210 and I can get a 360.2 for $270
I was gonna run this active:
midbass
tweets
subs
I was gonna use one amp
bridge 2 channels for tweets
bridge 2 channels for mids
since I can on this amp
I want more control of my mids and highs
talked to megalomaniac about it
said screw imprint
midbass
tweets
subs
so your going to run 2 way active, on a 4 channel amp bridged so its now going to be running 2 channels, and have mono tweets and mono mids, but yet you want more control............................................................................................................................................................................................................................................
audiofanaticz thats 4 way active...more than just about anyone needs. I don't even know of too many SQ competitors who run dedicated midbass...a solid set of mids that can drop low enough to transition to the sub is all you really need if youre not super fickle about your system. In which case, a 3 way active setup works fine without even one processor.
Subwoofer Wall
Guest Nismofreak
no like this
Posted Image
I want to adjust my tweets and mids to my taste
do you have all 4 comp sets up front or 2 in front and 2 in back?
because u are either going to lose fade or balance.... not a very good idea if u are going for more control
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
Guest Nismofreak
no
just using the front speakers. The back will be for looks i guess.
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
