sean 371 Posted March 19, 2008 Report Posted March 19, 2008 Admit it, does ANYBODY actually use fade or balance? you still keep you L/R stereo, and verrrry few songs have different F/R tracks. Running them active off the amp allows you to change xover frequencies and allows for some rough EQ changes. Definitely better than passive. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Kicker Guy Posted March 19, 2008 Report Posted March 19, 2008 Well personally I still use balance and fade.... and to be honest whats the point of going active if you are going to limit the control you have? Isn't the whole point to gain more control? Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
sean 371 Posted March 19, 2008 Report Posted March 19, 2008 You do gain control...over your xover points and the amount of power youre putting to your mids/highs...which i find a lot more important than fade/balance...and you still keep your L/R fade ability, just not your F/R A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Guest Nismofreak Posted March 19, 2008 Report Posted March 19, 2008 I wanna have a good front stage and give me control of tunning the mids and tweets to my liking
Kicker Guy Posted March 19, 2008 Report Posted March 19, 2008 You do gain control...over your xover points and the amount of power youre putting to your mids/highs...which i find a lot more important than fade/balance...and you still keep your L/R fade ability, just not your F/R your still limiting what an active system is suppose to be..... if your not going to do it right whats the point of doing it at all? I am not saying you can't do it that way but what I am saying is there is no point in going active to still have bridged tweets and mids when everything should be done separate for total control. Nismo if you are only worried about your front stage then do 1 speaker per channel Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
Guest Nismofreak Posted March 19, 2008 Report Posted March 19, 2008 your still limiting what an active system is suppose to be..... if your not going to do it right whats the point of doing it at all? I am not saying you can't do it that way but what I am saying is there is no point in going active to still have bridged tweets and mids when everything should be done separate for total control. Nismo if you are only worried about your front stage then do 1 speaker per channel I will be using tweets and mids if I wanna go active so I need to do what i drew
meade916 Posted March 19, 2008 Report Posted March 19, 2008 the thing is, with the 360.2 you CAN keep your front and rear intact.....and control them. If you decide to go active though, its easier to use (for example) "front" is now Tweeters, "Rear" is now "mids" and of course sub is still sub. (then you lose fader control, but F#ck it, at least you still have left and right ) if you want a true 3 way active setup (its four way but they still refer to it as three), you need 2 of these... mine is: 360.2 (1) - Front is midrange, rear is midbass, sub is sub 360.2 (2) - Front is Tweet and the other channels are left alone......they are there for me if i need them but not used. Basicly one 3sixty.2 is ONLY tweets. i coulda done midrange and midbass on one, and tweet, sub on the other......however i wanted, but this way was just as easy. The caddy im doing uses 1 and is a active passive setup. Rear is midbass, front is mids and highs (active into the amp and after the amp they will be seperated again with passive xovers), and sub is sub. Nismo, do you plan on getting an RTA or finding someone with one you can borrow? a 3sixty.2 is a powerfull processor but its not an EQ like the one you sheet-rock screw to your ash trey and play with the sliders.....you really should know how to do basic tuning before you make the leap......and an RTA is almost a MUST. If you dont use one, you willhave no idea where your problems are occuring......unless you think you can pick 850hz out of the "line up" as a dip and 1500hz as a peak (etc) with your ears (which you wont be able to do). this isnt just for Nismo, its for anyone with a 3sixty.2.....unless your using it JUST to integrate an OEM system and basic EQ functions, you will need an RTA to get to the nitty gritty. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
Guest Nismofreak Posted March 19, 2008 Report Posted March 19, 2008 yah a couple of my buddies have rta. I was gonna run the tweets in the front and mids in the rear outputs
meade916 Posted March 19, 2008 Report Posted March 19, 2008 that'l work bro.....i would bandpass the mids from 80 to 3500 and have your tweets set at HP from 2500 and up......bass from 90 down (give or take a little depending on your preferences) All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
Guest Nismofreak Posted March 19, 2008 Report Posted March 19, 2008 that'l work bro.....i would bandpass the mids from 80 to 3500 and have your tweets set at HP from 2500 and up......bass from 90 down (give or take a little depending on your preferences) yah. The mids I was gonna set a 120 and the hp at 2,500
