Subwoofer one way excursion?
I recently got a new amp and enclosure and noticed that the sub only goes inward and not outward. I switched the negative and positive speaker wire and it still does the same thing. Any thoughts or solutions?
Skar vvx12, 2.25cu @ 32hz, Precision Power PPI BK1800.1d.
the sound is clean but the sub never did before in my old set up. I wasn't the only one who noticed it and I feel like its probably not playing its full potential because its not moving as much. ill post a video of what I'm seeing.
So the sub moves the same way when you switch the cables? That's interesting. Do you have something that can mess up the phase?
my amp does have a phase align, but its set to 0 the last time i checked. im gonna have take the amp out reach the settings. the sub is a dual 4 wired to 2ohms. Also just went through and checked all the wiring and everything was correct.
But a battery, like a 9v (little block ones), and hook it up to the leads, it should move one direction, then switch the positive and negative and do it again, it should move the same but the other way (one will pull in, one will pull out). See what happens and report back.
  • Who's Online   0 Members, 0 Anonymous, 579 Guests (See full list)
