2 DVC subs into a mono amp
Just want to double check myself - I have two DVC 13W7's wired showing 3 ohms each hooked up to 1 Crescendo 3K. The final load is going to be 1.5 ohms, correct?
And then if I were to run each sub in parallel, I could get them down to .75.....?
Singer Alternators
Team Asshole
#anothershittysingerbuild
3/4=0.75 so yes, it would have a final load of 0.75 ohms. I know some Crescendo amps go to 0.5 ohms, but i would go the safe route and do 1.5 ohms. I wouldnt want my stuff to burn up haha.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Yes you can wire them series parallel to 1.5 ohm or parallel to .75 ohm.
To be clear, my question was does having each sub wired in series putting them at 3 ohms each and then hooking them up to the mono block amp with 2 speaker terminals bring it down to 1.5 ohms? I am just a little confused on that part.....the amp basically puts them in parallel once connected cutting the load in half?
*Technically I had two questions in the first post.
Singer Alternators
Team Asshole
Ok, so series-parallel gives 1.5 and then parallel-parallel would give the .75. Thanks!
*I know this is a very simple question and I'm probably making it more difficult than it is but I'm trying to learn! "I'm here to learn people, not make out with you....go on with the chlorophyll!" (couldn't resist!) :roflmao:
Singer Alternators
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
