Daddy_ Posted May 27, 2014 Report Posted May 27, 2014 Just wanted opinions on the Audio control LC7i or LC8i. I have the 2012 TL Tech. So it has navi and all and want to keep the factory deck. Is this a good choice or is there anything better? Also I'm sort of confused about something. The audio control device will only help me get a signal to my subwoofer from factory deck? If I want to run a sound processes like a RF 3sixty.3 or a Audion Bit one is that totally seperate? The processes will just help me tune the sound? If I want to keep the factory deck I will have to use the Audio control or a JL Clean sweep? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
OrionStang Posted May 27, 2014 Report Posted May 27, 2014 I don't see why you need the AudioControl piece AND a processor. A 360.3 alone should do you just fine, its made for factory integration. SMD Super Seller My Feedback Thread
Daddy_ Posted May 27, 2014 Author Report Posted May 27, 2014 So just a processor is fine ? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
islandpride684 Posted May 27, 2014 Report Posted May 27, 2014 So just a processor is fine ? Yes Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
JesseyMclame Posted May 27, 2014 Report Posted May 27, 2014 Bit one. Current setup in my 96 Hoe Hu - Pioneer DEH-80prs. Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets) Batts - 4 91ah rear batts, 50ah batt up front. Subs - 2 Crossfire XSv2 18's Alt - Singer 330A Front stage - Random JL & Eclipse mids, Eclipse tweets
AudioControlMT Posted May 28, 2014 Report Posted May 28, 2014 Daddy_ Have a look at the DQ-61 OEM Processor w/Signal Delay (click link below for more info). You can very easily integrate with the factory system in your TL. As for your question about creating a sub signal, our processor will create a separate signal from second input (three inputs total). Also, all of our OEM processors (except the LC2i) have signal summing, so you can combine separate tweeter and woofer signals if your factory system has them (usually in the front). To top it off, each channel has an independent EQ section. Go to your local installer to audition one; we're sure you won't be disappointed (Dealer Locator). DQ-61 22410 70th Ave West Mountlake Terrace, WA 98043 USA P. (425) 775-8461 F. (425) 778-3166www.audiocontrol.com
