4th order walled Civic (DC/PSI 18's/CF 8K/ RF 360.3 UPDATES APRIL 24-2015
I'd go with the Pioneer
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
See thats my problem, I like the Pioneer deck and I have been using it for over a year now. After it got modded its a little slow on boot up times, I like the bigger screen on the JVC but I'm used to the Pioneer. lol
JVC has more EQ capabilities and a higher preamp voltage, but its up to you bro....i would just put both of them in...lol
  • 3 weeks later...
So not much has been done to the build as we are moving and is on hold till after we move. But I have order and got a few things, 5M of RGB LED lights, male and female pig tails, switches, terminal strips, soldering iron, a few fuse blocks along with few other things. Everything is packed and already at the new house including the car.
But I started thinking about my build a was wondering a few things.
I would like to try a 4th order wall and was wondering for a 2:1 set up
If I remove the baffles and port I have 17.95 cube to play with what would be my choices on subs?
I can alway rip the wall out and start over to gain more room, with a double layer shell. Right now my wall is pretty thick and I know I can gain more cube by starting over. But for now lets say I use my shell I have now.
Moving right along! The radio mount looks nice man.
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
