My turn signals and my cruise control(on steering wheel) Both went out, they do not work.
My hazzards work and so does my horn, but those 2 do not work.
I changed out the "flasher" unit and it didnt effect the turn signals or the cruise so i put old one back in..
I checked my manual for a fuse or something and doesnt say any fuse for cruise control or turn signals. it gives info on the turn signal relay and says located under steering column.. But only thing there is flasher and already tried that.
Any ideas fellas?
Its a 2000 Ford Contour Sport (if that helps any)
06 SCION tC
If all else fails just look for a broken or burnt fuse since it doesn't say exactly which one it is.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
yea, and keep in mind most vehicles have two fuse boxes, one in the car, and one under the hood,... It would be a good idea to search both of those for any burnt/ loose fuses and fix the problem. That should help.
A vitrolic, megalomaniacal sadistic psychopath.
Something similar happened in my dad's caddy chekc your manual for fuses like "cabin comforts" or something I forgot what his said it was something along those lines.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Posted (edited)
Does your horn work? Air bag light on?
Could be the clockspring, thats fairly common when symptoms like yours occur.
Your likely to have seperate fuses for those systems, I would tend to look at what they have in common, ground problem maybe but I would put my money on the clockspring as your going to constantly be turning it.
To replace it, if thats the problem, is take the air bag off, remove the steering wheel and then the steering column covers and it should be easy from there. Just make sure you disconnect the battery and wait a few minutes before you start taking things apart. If your not comfortable about doing any of that, definitely take it to some one.
Edit: Looking closer your cruise control switch is on the steering wheel and your turn signal switch is not. So the clockspring may not be the problem. Its possible you have two seperate problems and found them both because one that you use more stopped working?
Edit2: Check fuse 23, 15amp in the central junction block which is located under dash on left side.
Hope this helps.
Edited by toytrkdrvr
  • Who's Online   0 Members, 0 Anonymous, 638 Guests (See full list)
