IH8PunkRok's Magnum *Yay New Engine and Tablet Dash*
Looks real good! Could you put some thin foam tape around the port and then put them wire screen on that? It might help with the flapping and rattle.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
That would quiet it down but the part that makes the most noise is the cloth. It acts like a kite
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • 3 weeks later...
So my friend Denny (GTOGuy) helped me solve the problem of my flapping port cover. He said to get some metal that would work and just polish it to match the aluminum rails I'll be adding.
So I did
Now in order to make this thing flush I needed to raise is 1/2" from where it was mounted on the box. So that means bending
This piece is being used to essentially flush mount the sub so that the floor can sit level
Unfortunately this is a terrible picture of it but the floor is now sitting flat, the port cover is installed, and all is looking good.
Tomorrow I will be bonding the flush floor and the pretty floor together so that I can have something quickly removed.
I will also be installing these
I have 4 of them. These are to hold up the part of the floor that does not have the box under it when I am carrying something that would make 1/2" of wood bend
I also covered the tops in silicone. Stop rattles before they happen *the more you know*
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
The floor is now completely functional
First I installed the brackets ^
They dont go out very far but every little bit helps when the wood is thin
I pl'd the flush panel to the beauty panel and now it is one solid removable piece
Next was to line up and mount the port cover
and boom
Seats up
And so all can see, they are indeed flush.
Now I can start worrying about how to trim it all out to get rid of the nasty edges. And aluminum. there will be aluminum
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I got to go to my parents house and my Dad has every tool one could imagine and loves to help with my projects. Needless to say we put in work
I had looked at actual aluminum pieces for the trim, but it was expensive and I had no way of cutting it. So I opted for some cheap sticky shit.
I know for a fact that dude at advanced auto judged me hardcore as I was buying this lol
Anyway I taped and painted the port cover. I wanted all but the top surface to be black so it would blend in. The top was to be polished
Next we fixed the crappy jigsaw cutout I had made with a router and prepared it for the trim pieces
*NOTE* pay no attention to the backside material as it will not be seen
Next was the sketchy part. The trim I bought for the port and sub is the u shaped trim for doors. Turns out this wood was far too thick for the opening. So we fixed it with a router, a rabbet bit, and a steady hand
We did the same treatment to the port side. Next I was able to attach the trim.
It was this moment I began to get excited and thusly forgot to take pictures
Unfortunately the extruded port cover was not going to work with the trim due to lack of material around the port. Luckily it was steel and bent right back to flat. We then took the flat piece and sandwiched it between the floor and another piece of wood below the trim.
It gave the piece a nice recessed look that I really like
Next step was to put it in the car and lay the large trim pieces.
and voila
I still have some areas I need to work on to give it that real OEM look but I am quite happy with it
excuse that piece of dust on the sub... didnt notice it until now. bleh
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1342 Guests (See full list)
