IH8PunkRok's Magnum *Yay New Engine and Tablet Dash*
So the idea behind this build had the following requirements
1. Usability- having a wagon means space, having a system means no space. compromise
2. Still able to get decently loud. Making a good first impression
3. Fidelity. I sacrificed my staging for larger components specifically for this
4. Class. It has to look good and be tasty
Equipment list
2005 Dodge Magnum RT
JVC KD-AVX1
Zapco 650.6
Audison AX 1.1
Hertz EV 130
Silverflute W17
Audison Sr1dk
Tang Band W8 SBF
XS D1200
2 Deka 9a31s
Shok 1/0
More pictures to come
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Now the first obstacle to tackle was my front stage
the esk 130s are a 5.25" driver that I really love the sound of so I paired that with some Audison AX 1.1s and decided that would be my pillar. The Silverflutes would go in the door as usual
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
The next problem was my bass. How can I get enough bass to satisfy my needs while still being as small as possible. I toyed around with sealed, bandpass, ported, all types of enclosures, weird shapes, and odd places so that I could retain my wagoness. Eventually I settled on the king of output. T-Line.
I bought the 8 to try and keep it as small as possible. Also I made it extremely thin so that it could sit where my cargo shelf is in the car
Credit goes to Matt Wilson for my box build
1013271_10202900733820152_1058039687_n_z
1601362_10202900733900154_275821802_n_zp
1656392_10202900733860153_1175857747_n_z
And here is how it sits in the car. Originally I wanted to to be lower but my wheel arches got in the way so I had to make due
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I like the build. Love the amps, A pillars look really good, and I like the T-line. No one is going to expect the output out of that :)
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I drove around for a while listening to it and I am quite pleased with the output and fidelity so I started making it pretty
First step
Wood
You can see how my zapco is mounted. The Audison is mounted under the box
I scored that flooring for $5 from a Peddlers Mall
As soon as I got home I began the Mock-up
You can see that the pieces are a bit too wide for the car. Instead of just cutting that last piece down I opted to split the difference between the first and last board. Symmetry is a good thing.
Then I began the curving process
Not perfect but it will do
Then to cut out the sub hole. This was a ton of trial and error
But it worked out well
Next the port
Boom
I plan to get some aluminum strips to lay between some boards to break up the wood a bit. Also paint and cover the port so things cant fall in it. Trim the port and sub in maybe aluminum, maybe not.
Still need to figure it out. Opinions?
I will get to work on my pillars and dash soon as well.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Would definitely trim the sub and port in aluminum. Would look sick. I'm intrigued to see how this progresses- looking to do something of similar cleanliness and practicality in my car.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
looks sick man....you had my attention with that Zapco 6 channel :wub:
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I thought I was smart
Had an old trash can which is made of material perfect for a port cover
fits the hole nicely but wrong color
Paint it
Combine with speaker cloth
and it looks good
but it flaps like a fucking bird...
boo
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
