vizzual_blur Posted June 2, 2014 Report Posted June 2, 2014 Never ran into this issue before, the car hesitates and shutters as the bass hits, also causes the car to shift funny, like it skips. Setup is saz1500d, 12" aa havoc, 1/0 wiring, scha gear. No big 3 until this weekend. Standard group 35 battery stock alt. either the problem is coming from the electrical system not being able to handle the draw? Or if anyone has a g35, the positive terminal has this weird fuse system on it, I used a marine grade terminal, lug is on first then the fuse setup on top of it. Im not exactly sure of how to get around this to hookup at the battery another way and I still have another amp to hookup :/ Would the big 3 fix this is what? As soon as I turn it down it stops.
808faka Posted June 3, 2014 Report Posted June 3, 2014 did you try checking the voltage at all while playing it. and doing the big 3 will help, but not necessarily fix it. only so much stock electrical and battery can take.
Nealon14 Posted June 3, 2014 Report Posted June 3, 2014 You can buy a new terminal that holds all the connections you need and run a jumper cable from the factory fuse to the new terminal. check this video out at a little after 4 minutes
vizzual_blur Posted June 3, 2014 Author Report Posted June 3, 2014 did you try checking the voltage at all while playing it. and doing the big 3 will help, but not necessarily fix it. only so much stock electrical and battery can take. im going to check the voltage tomorrow, after work if I have time, if not it will be Wednesday. I have a feeling I will be getting a new xs battery at minimum, possibly two. I may make a solid copper bar to jump the oem fuse thing to a better terminal also.
808faka Posted June 3, 2014 Report Posted June 3, 2014 can never have too much when it comes to electrical upgrades.
FCS530 Posted June 3, 2014 Report Posted June 3, 2014 It really sounds like you are dropping the vehicles voltage far enough to make the PCM go goofy! Big 3 could help or possibly completely fix it. You have to realize how tiny the alternator charge wire and body ground cables are. They can't carry enough current to keep up. Several systems, several vehicles. Always changing! 2013 MECA State Champion (trunk 1) 2014 MECA State Champion (mod 4) 2014 MECA state Champion (Park and Pound 4) 2014 DBDRAG 6th place North America Finals (SS1-2) 2014 BASS RACE 6th place North America Finals (139.9)
SmallTruk Posted June 3, 2014 Report Posted June 3, 2014 You're system is robbing the engine and ecu of current. The big 3 will probably help during regular driving while the system is down but with the stock battery and 110a alt, there's just not enough power to supply both the engines needs and the system. I'd definitely recommend some upgrades before adding the second amp otherwise there's a chance you might fry something (possibly with the cars electronics)
Aj11 Posted June 4, 2014 Report Posted June 4, 2014 a couple things, 1) what ohm load is your amp seeing? 2) how many amps is your stock alt? 3) how old is the alt? if you've had that amp @1ohm on a stock alt for a while odds are your alt is dying. I've gone threw the stocl alt on every car I've ever bought. 4) in rare and i mean very rare cases doing the big3 can actually.make the voltage.drop worse! and in your case that would mean your car would shut off. the reason being that now your amp has a " bigger straw" to suck power threw. i had that happen with my Saturn sl. had a single jl 500/1 and i Would drop down in the high 10s. did the big 3 within a week And i hit a 8.4 to my surprise the car didn't shut off. i knew right then time for a new alt. i got a new one and added another 500/1 and didn't drop below 12. not bad for a 95amp alt. i just wanted to give you the heads up that the big 3 doesn't always fix the issue. sometimes it makes in worse... rare but it does happen. find your dropping voltage before you do the big 3. your skinny wire might be the only thing saving your alt from completely dying! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
vizzual_blur Posted June 4, 2014 Author Report Posted June 4, 2014 You're system is robbing the engine and ecu of current. The big 3 will probably help during regular driving while the system is down but with the stock battery and 110a alt, there's just not enough power to supply both the engines needs and the system. I'd definitely recommend some upgrades before adding the second amp otherwise there's a chance you might fry something (possibly with the cars electronics) checking drop tomorrow, stock alt is a messly 110, id assume its 163k miles old, im running @1 ohm. I noticed this issue immediately upon driving the car. Ive since turned the gains down to half until I can check it all out.
Aj11 Posted June 5, 2014 Report Posted June 5, 2014 wait what? you turned your gains half way down? meaning they were all the way up? if so there's your problem! if you were clipping that hard @1ohm on.that old of a alt no wonder your car is dying! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
