So I am in need of a amp because mine is just plain bad... Higher bass notes sound muddy and distorted and I really want some good SQ. Money is an issue so i was looking around and found this http://www.savinglots.com/lotprod.asp?item=STL1.600D&gclid=CjkKEQjwqsCcBRDt7_Gts5a91YYBEiQAm-wYEaeYHXj6tqMFNVuKrxDvAt0rGJxgwUnSfGE0ml9IW77w_wcB . Which is a Soundstream STL 600.1. Would this amp match well with JL Audio W1v2-4 12's? In a sealed enclosure? Thanks for your help:)
Yes, perfect match, not much headroom tho. i'd prob suggest getting a better amp that's 1ohm stable just incase you decide to upgrade the subs later on. amp does 600rms at 2 ohm, thos subs are single 4 ohm so wire them to two ohm. the subs are 300rms.
I wouldn't buy threw that site. Go threw amazon, sonic electronics or 3 kings audio. More reputable and save a couple bucks.
truthsayer
You are not going to get anything with good sq for $100. Will it work for those subs yes , would I save up and buy something nicer you bet your ass I would.
Also next it might help if you post in the right section and don't be so impatient people do have lives other than answering questions on the internet.
  • Who's Online   0 Members, 0 Anonymous, 2486 Guests (See full list)
