baron_of_bass Posted June 9, 2014 Report Posted June 9, 2014 anybody know how i can hook up 2 crown xls1000s to a home audio receiver? im trying to figure this set-up up before i start buying stuff... im trying to run a pioneer VSX-824-K to 2 crown xls1000s. Hope that makes sense, if its even possible. Team Bass-Hz
truthsayer Posted June 9, 2014 Report Posted June 9, 2014 That receiver only has subwoofer pre outs. If i'm not mistaken your needing a receiver that has pre out's for all the channels. ( that.s if this is a continuation from your other post) Edit: This one has the pre outs you where looking for. http://www.amazon.com/Pioneer-VSX-1123-7-2-Channel-Network-Receiver/dp/B00BKXCKRC/ref=sr_1_2?ie=UTF8&qid=1402358055&sr=8-2&keywords=pioneer+home+receiver truthsayer
Soccerballzs Posted June 9, 2014 Report Posted June 9, 2014 You may need xlr to rca leads also. Plus a separate tuner and crossover for sub. That is how I run my. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
truthsayer Posted June 10, 2014 Report Posted June 10, 2014 You may need xlr to rca leads also. Plus a separate tuner and crossover for sub. That is how I run my. He can use just the rca's. I checked it out to make sure. truthsayer
baron_of_bass Posted June 10, 2014 Author Report Posted June 10, 2014 You may need xlr to rca leads also. Plus a separate tuner and crossover for sub. That is how I run my. He can use just the rca's. I checked it out to make sure. so the receiver that i want to use wont work for what i am trying to do? Team Bass-Hz
White Lightning Posted June 10, 2014 Report Posted June 10, 2014 use the reciever outputs for the mids and highs and run RCAs to you sub driver amplifier using the sub output of the reciever. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
truthsayer Posted June 10, 2014 Report Posted June 10, 2014 The receiver you want only has a sub pre out, so if you want to use it. You will have to power the mids/highs with the receiver and you can power the subs with the amp. However if you are wanting to use the amp to power the mids/highs you will have to get a receiver like the one i showed you, that has the pre outs you need. truthsayer
baron_of_bass Posted June 10, 2014 Author Report Posted June 10, 2014 The receiver you want only has a sub pre out, so if you want to use it. You will have to power the mids/highs with the receiver and you can power the subs with the amp. However if you are wanting to use the amp to power the mids/highs you will have to get a receiver like the one i showed you, that has the pre outs you need. Thanks for all your help Team Bass-Hz
truthsayer Posted June 10, 2014 Report Posted June 10, 2014 Baron, i found you a cheaper pioneer receiver with L,R and subwoofer preouts for $230. http://www.amazon.com/gp/product/B007O5ATM8/ref=s9_simh_gw_p23_s10_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-4&pf_rd_r=17BGX40GJ9TEGANS3TJ1&pf_rd_t=101&pf_rd_p=1688200422&pf_rd_i=507846 truthsayer
