On those measurements I don't see it mention a double baffle or bracing. Such a big port needs to have bracing to.
the part the speakers mount to in the back is called the rear deck.
also kinda doubt you could have 60" of width in the trunk. Most suvs are only around 45-55" width. I just don't see your Vic having the same wheel well to wheel well measurement or bigger then most suvs.
also if max height is being used for the height of the box where are the subs being mounted? They need room between them and anything above them in order avoid issues.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 495 Guests (See full list)
