Caps! Need some advice and help
ill have a video today of what 8 banks can do with 2 m4s strapped on a ddz @ .5 ohms (.25 each amp). all i can say is, what drop?
So would you feel safe bumping your system on a long drive with those caps?
yea definetly. why wouldnt i? whats the difference between a long drive and a short drive?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
A long drive is longer than a short drive lol. What I meant by it since caps don't carry the reserve batteries do you don't worry about them getting hot after a while. Being that they simply haven't been as tested in daily setups as they have been for SPL.
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
they get hot like anything else. is an hour drive long to you?
if so then theyre good to go lol
you gott ask yourself..
do i want to hold voltage in the 12s after my alt can supply no more and carry around hundres of pounds
or
do i want to hold voltage where my alt charges and slowly decline into the 13s after stuff gets hot (assuming you dont have a enough caps)
well i am testing in a daily setup. I know snowdrifter and slammin have as well. under a daily load even if you full tilt everywhere the caps will be fine. no matter how long or how hard you play. your subs or alternator will give out first.
BMW M340 xDrive
or
But is a H/O alt still needed for more power than an original stock alt can provide? Meaning, if I'm running 4000 watts, will a stock alt that's 130a with an ultra cap be sufficient.
or
an alternator allows you to play longer. sure you can run a 9k on a bank of caps, but not for very long. the alternator is and will always be the source of power.
BMW M340 xDrive
daily for days. pretty constant bass too on a stock alt
BMW M340 xDrive
