Triticum Agricolam Posted June 17, 2014 Report Posted June 17, 2014 And brace the hell out of it IMHO, this is more important than doing a double wall. If you get your bracing done well enough you won't need to double up anywhere other than the baffle. Google "speaker window braces" for some ideas on how to do the bracing well. I shoot for not more than 10" of unbraced span. I would also recommend an external port. Doesn't have to be an aero port, but I'd do something that you can easily remove at least part of to change the tuning. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Bump4life Posted June 17, 2014 Report Posted June 17, 2014 And brace the hell out of it IMHO, this is more important than doing a double wall. If you get your bracing done well enough you won't need to double up anywhere other than the baffle. Google "speaker window braces" for some ideas on how to do the bracing well. I shoot for not more than 10" of unbraced span. I would also recommend an external port. Doesn't have to be an aero port, but I'd do something that you can easily remove at least part of to change the tuning. i want to semi disagree. it depends on where port is as well. the port itself can act as a brace. my box has double layered walls and no bracing and doesnt flex at all. its is all about construction. i also use tongue and groove construction with a quad front baffle and center port. fiberglassed all the corners in addition to glue Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
SlamminBeats Posted June 17, 2014 Report Posted June 17, 2014 And brace the hell out of it IMHO, this is more important than doing a double wall. If you get your bracing done well enough you won't need to double up anywhere other than the baffle. Google "speaker window braces" for some ideas on how to do the bracing well. I shoot for not more than 10" of unbraced span. I would also recommend an external port. Doesn't have to be an aero port, but I'd do something that you can easily remove at least part of to change the tuning. double wall over bracing...
boom50cal Posted June 17, 2014 Report Posted June 17, 2014 2 6 inch ports works great on a Tantric HD 15... I'm runnnig that. 3.8 cubes, 2 6 inch ports, 16.8ish sq/in per cube. Not too peaky but really musical. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Daboxxstl Posted June 18, 2014 Author Report Posted June 18, 2014 2 6 inch ports works great on a Tantric HD 15... I'm runnnig that. 3.8 cubes, 2 6 inch ports, 16.8ish sq/in per cube. Not too peaky but really musical. I'm not needing to play music. It is a strictly burp setup I'm going to build
Triticum Agricolam Posted June 18, 2014 Report Posted June 18, 2014 ... my box has double layered walls and no bracing and doesnt flex at all. its is all about construction. i also use tongue and groove construction with a quad front baffle and center port. fiberglassed all the corners in addition to glue I'm sure you box doesn't flex. I'm not saying using double wall construction doesn't work. I know it does and anyone that wants to do that way can get good results. What I'm saying is proper bracing is better than double wall. It will be stronger, uses less material, and will take up less volume. Let me show you why: Here is a hypothetical box, 32" x 16" internal dimensions, using 3/4" material. This box has a 32" unsupported span on the top and bottom, and a 16" unsupported span on the sides. If we double up the top and bottom they will be twice as stiff, it will make them equivelent to a 16" unsupported span: I can get the same stiffness with just adding one brace though: Now if I take this to the next level and put in braces in both directions that are tied together you end up with an extremely stiff box, the longest unbraced span is only just over 10": Even a fully double walled box isn't going to be anywhere near as stiff, and will use a lot more material, which is just wasted weight and space: "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Daboxxstl Posted June 18, 2014 Author Report Posted June 18, 2014 So use some pine rod as the reinforcements? Or something else? What would you guys recommend?
SlamminBeats Posted June 18, 2014 Report Posted June 18, 2014 So use some pine rod as the reinforcements? Or something else? What would you guys recommend? not pine iron
