Rookie needs help with burp box
Daboxxstl
The iron pipe with flanges works well.
You can also use 1" or larger hardwood dowels. If you use dowels the right way to glue them in is to drill through both sides of the box, put glue inside the holes, and then tap the dowels in. After the glue dries you can cut off the excess that sticks out. This way gives you the most surface area to glue to.
I just build my braces out of MDF. Here is an example of how I do it:
Builds:
Fiberglass is nice for strengthening corners in an enclosure but it won't do much as far as panel bracing unless you use a minimum of 4 layers of ~3oz chop mat over the entire surface... which is a total waste of time and money relative to wooden or all thread braces.
For the power you plan to run, a nice, tight joint with plenty of glue will be strong enough. On a box like that I would use 15 gauge nails as the fasteners and I'd put them about 3' apart. Never underestimate the strength and sealing ability of Titebond II, lol. ← Again... when you have tight joints.
If you don't have tight joints, then a narrow strip of chop mat and resin will suffice to strengthen and seal the corners. But don't use caulk and never... ever, use silicone. The latter provides no appreciable structural benefit and it has almost zero adhesive properties, especially when applied to wood. It also makes a fucking mess of paint work.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
When doing braces such as this how do you calculate displacement?
When I design the box in SketchUp I plan out the braces in there as well. In SketchUp, if you open up the Entity Info box it will give you the area of any surface you want, from there its pretty easy to calculate the volume. The way I do braces they don't take up much volume at all. They are actually a lot quicker an easier to make than they look too. They don't have to be pretty to be functional and you can cut them out with a jigsaw pretty fast.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
