spl wiring questions
Ritch40
I am currently to the understanding that to achieve the best possible spl within a given setup that you want your subs all wired in parallel.
my question is this, if that is the case, does the whole system need to be in parallel all the way to the amp? Or is it just the voice coils that need to be wired in parallel??
Thank you in advance for any replies.
p.s.
I am trying to sort out what voice coil configuration i need and what amp or amps i need to run 4 12" subs
Thanks again!!
parallel lowers the ohm load is why it might increase the db but do not wire below what the amp can handle.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I had no plans to drop impedance at the amp lower than what manufacture says. just trying to figure out what impedance i need in my voice coils and what amp or amps i need.
thank you!
Most common setup for two subs is to have a 1 ohm stable amp and two 4 ohm dvc subs. So in this case you can wire both in parallel to get 2 ohms each then parallel to the amp again to get 1 ohm. Or alternatively two 1 ohm dvc subs, wire them in series to get a 2 ohm load then parallel to the amp.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
what i want to do is run 4 subs off of 1 amp
i think if i wire each sub parallel and then run a pair of subs in series this will accomplish my goal of keeping the voice coils anyway in parallel.
i just dont know if running 2 subs in series will hurt my spl or not. it would seem anyway that the main thing is to keep the voice coils on each sub in parallel.
if i am wrong on that by all means please let me know.
thanks
Ed Lester did a video a while back showing why putting voice coils in series lowers spl. I think that is where this is coming from.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 2647 Guests (See full list)
