Prosper506 Posted June 24, 2014 Report Posted June 24, 2014 I currently own a Rockford Fosgate P3D4-15" subwoofer, and the specification sheet that came with it suggest a maximum ported enclosure volume of 2.5-3 Ft.^3. But with every program i have thrown the box and driver into(BassBox6, WinISD) they both show with a box that size that peaks at around 50 Hz, even tuned to something low like 26 Hz, The only way to lower these peaks down to around the 30Hz range is to increase the enclosure size to closer to 10 Cubic feet! is there some kind of technical error or is it on my part? Any help would be appreciated!!
agf144 Posted June 24, 2014 Report Posted June 24, 2014 that doesnt sound right if anything put it in 3.5 cubs and tune it to 32hz and you should get the response you are looking for Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
Prosper506 Posted June 24, 2014 Author Report Posted June 24, 2014 that is what i figured, so should i go ahead with the construction of an enclosure to those specs and pay no mind to the output graphs?
agf144 Posted June 24, 2014 Report Posted June 24, 2014 no honestly i wounld do a 4th order if you have the space. thses graphs wont be 100% accurate but gives you a rough estimate. blue line is the 4th order tuned to 45hz and green line is a ported box 3.5 cubes tuned to 32hz Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
Prosper506 Posted June 24, 2014 Author Report Posted June 24, 2014 Well the 4th order does look better, so it is normal to have these peaks around 40 Hz? By the way thank you for taking the time to help me out!
agf144 Posted June 24, 2014 Report Posted June 24, 2014 no thats not normal its just the sub. but your sub will work well in a 4th order bandpass. Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
Prosper506 Posted June 24, 2014 Author Report Posted June 24, 2014 alright i'll try my hand at this, thanks!
noobslayer77 Posted June 25, 2014 Report Posted June 25, 2014 always anxious to see how a 4th order turns out... i was thinking about doing one for my 2 w7s, but i don't have the space. 2004 Jeep Liberty Limited 2 13w7s skar 3500 cnf mids (soon) xs batteries
