Joe X Posted June 27, 2014 Report Posted June 27, 2014 Here are supposedly the parameters for those subs: TS-W302FNominal Diameter 12"Fs (Hz) 33,4Qms 17,754Vas (l) 105,62Cms (mm/N) 0,286Mms (g) 79,49Rms (kg/m) 0,94Xmax (mm) Slaglängd 6Sd (cm2) Effektiv konarea 511Piston dia. (cm)Qes Elektroniskt 0,494Re (ohm) 3Le (mH, vid 12 kHz) 0,618Z (ohm) 4BL (T*m) 10,225R.M.S. Power (W) 150Qts Totalt 0,481Efficiency (%) EffektivitetS.P.L. (dB/Wm) 94Max Music Power (W) 450Sp. Displacement (l) 2,02Vd (l) 0,306Zmax (ohm) . 114,2Magnet Wt (g) 1240Flux Density (Guass) 10500Magnet Gap L. (mm) 10V.C. Lenght (mm) 22V.C. Diameter (mm) 48Vas (ft3) 3,73Vd (ft3) 0,0108Sd (ft2) 0,55 150W, 6mm Xmax & old as hell, a total waste of time, tell your friend to sell those things for whatever he can get and find some half decent subs that works well in the space he has.
KiKaZz74 Posted June 27, 2014 Author Report Posted June 27, 2014 What's something that would be pretty good? Not looking for much. Skar sundown Dc Kicker Alpine C2 Ct And what do u think he could sell them for? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
Joe X Posted June 27, 2014 Report Posted June 27, 2014 For a small box DC and alpine 5th gen are best, other than that is a matter of personal taste, power handling etc.. he would need to make his mind about that, those pio subs are worth nothing IMO so whatever is the most he can get for them that would be fine.
KiKaZz74 Posted June 27, 2014 Author Report Posted June 27, 2014 I think I'll shrink it down to 16d and 20d That's give me around 5 cubes before port and sub and bracing displacements. What's an average daily tune? 34-37? I'll talk to him tho see what he wants to do. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
