Set my gains with DD-1 No distortion at max gain
Turn up the subwoofer preout volume on the radio if there is one.
If its turned down chances are your sending almost no voltage to the amp via the RCA cords, which means your amp is not putting out anywhere close to the power it should most likely.
There is no way the amp is set at MAX gain, unless something is screwed up or not set right.
I have a hard time believing that your dual deck only puts out 125-250mV or less on the RCA preouts, because with the gain is set on max on your amplifier thats all the voltage going into it from the RCAs. Thats 1/4th of 1 volt RCA preouts, or even less depending on what setting you have selected for the input level on the side of your amp.
So check to see if you have a subwoofer volume on your radio, if you do turn it up.
Try changing the input selection on the side of the amp from 250mV-10Volt setting to the 125mV-5Volt setting.
Its a little push button switch, push it in for high level input, or have it out for the low level input setting which is what you want.
Its crazy how much HU will make the difference on how much gain is used. I just went from a Kenwood kds355u witch clipped at 29/ and gain on amp was just about 1/2 way up. Now I have pioneer avh-x3500bhs witch clipped at 35. same amp and now can set my gain at just about 3/4 way u. Set with DD1
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
The amp is now on the left side of the box so wires arent showing, i was building a box but my buddy sold me that one for $70 it luckily has perfect specs for the subwoofers.
Anyway
I am about to start putting in deadener and mids/highs. Ill post pics of the process.
I had a us amp m1d1 do this also op
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
  • Who's Online   0 Members, 0 Anonymous, 2473 Guests (See full list)
