2002 NEO Caddy, ROCKFORD FOSGATE, 4-T3S2 19's, 8-T2500.1bdCP, SINGER 370, XS Power
After taking everything out and securing the wire I had already been working thru the night and into the next day. Who sleeps when they could be working on there ride! :lol:
Here is the engine bay all finished for now, dont mind the dust/grime im gonna clean that up when it isint as cold!
Anyway here are some pictures of the assembly of the interior, I got almost all of the process but then my phone ran out of juice and got tired haha.
Annnddd....thats all I got, I thought I got more pictures putting everything back in, but oh well.
I am very thankful of my parents, they let me work in there back yard with this view!!!!
MIDS-HIGHS
8-Rockford Fosgate Punch Pro 6.5's for now....
2-Rockford Fosgate Punch Pro 8's
4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters
2-Rockford Fosgate Punch Pro 10's
AMPLIFIERS
4-Rockford Fosgate T2500-1bdCP
2-Rockford Fosgate T1000-4ad
1-Rockford Fosgate T800-4ad
PROCESSING
1-Rockford Fosgate 3SIXTY.3
SUBWOOFERS
2-Rockford Fosgate T3S2 19's NEODYMIUM
During most all of my building I always had help from my friends........ a huge thanks to all of them....even when they troll the crap out of me haha, so a huge thanks to them and everybody else who helped me build! Good thing one of them has a truck haha or I would have had to make multiple trips to the Depot to get mdf.
The sheets fit perfect in the bed, this is only a couple sheets. I bought about 7-8 haha
While I was there I got some threaded inserts and allen bolts along with some new router bits!
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
Alright, so I have made three single sub enclosures while i was waiting for my second sub to come in. I didnt take many pictures of them because they were just temporary. Once I received my second sub I built two enclosures so i will post both of them up.
Here is the start of the baffle, I only did a double baffle. I used screws and tightbond two.
Here is a picture of my twins lol they are huge! :rockwoot:
They are dusty but oh well, I cleaned them off later....also hide your eyes from the hideous box they are on!
This is the first enclosure I built, it was tuned to around 28hz using Torres but it didnt have enough net volume, I loved the port because I could crawl into it and I could float hats and towels in it!
I know that it is frowned upon to put your amp on the enclosure so I did anyway lol for about a week, then I relocated it to somewhere safe!!! I also didnt have the gain set anywhere near where it should be for full output. I ran just the one set of power into the amp from the XS power d3100 because I was going to change it a week after.
After about a week I decided that I wanted to make another box because this one was just off and didnt have the range I wanted so I started to build a new enclosure. I designed it using Torres and some math! I didnt get very many pictures at first but here they are.
Here are some 45s
I sealed up the box and i used my flush trim bit to cut out the port.
Here is a picture of adding a new double baffle and port bracing! I also used the sub for weight lol
There is my most current picture of my box, I have added some more bracing and some other little things.
This weekend I am going to start on door pods so I will update when I have pictures!
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
Looks pretty good so far man ? . If I may ask.. why Did you do the 2 ground runs from the battery back? Instead of just grounding to the frame in the rear?
Regardless I'm tuned in
Thanks for looking, I did the two runs back just because really, I wanted a good ground I guess haha, also If I was going to upgrade soon I could always throw some wire loom on the wire so it was all the same color and use it for more positive runs back. Thanks for looking!
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
That's a good idea..
You're taking your time to do it right. :good:
I'm tuned in.
What do you plan for your front stage ?
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Thanks, it hopefully will work well!
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
I'm tuned in.
Well I purchased a sax125.4 and I just got some pwx 6.5's at my door today, so I'll post updates this weekend!
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
Ok so recently I realized that my rotors had some deep gouges/ groves in them, so i purchased an EBC brake kit, I figured it would be a good idea also because I will be adding more weight and be getting bigger wheels. I was very happy with the quality of the rotors and the green pads that came with them.
Here are the front
This is the rear
After I had removed the rear rotors i noticed that my park break shoes were worn down all the way past the brake compound lol so I replaced them also! Now my Parking brake actually works haha
Dirty Dirty Rotors
Fresh new rotors!
I didnt get very many pictures of the other side because I noticed that my oil seal on the axle was leaking, so I had to unbolt the back of my rear differential and pull the axles out, then I sealed it all back up after I replaced the seals. I used copper high temp gasket when I put the cover back on the diff along with the oem paper gasket, So far so good!
Here is the front rotor!
After I installed the new rotors and pads I followed the break in procedure that EBC recommends and the brakes feel better than ever! 8P
MIDS-HIGHS
AMPLIFIERS
PROCESSING
SUBWOOFERS
  • Who's Online   1 Member, 0 Anonymous, 1711 Guests (See full list)
