4th orders
I have two FI BTL N2 15's ( fully loaded) I have been told not to run them in a 4th order but no one can tell me why. The only reason I can figure is because of cooling issues. Can anyone explain why it is not recommended to run these in a 4th order and if it is because of cooling issues would inverting the magnets into the ported section solve the problem
because the qts on the parameters of the sub would recommend a ported box or a 6th order if I am mistaken someone correct me
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Qts does not determine what enclosure you should use your driver with. Qts characterizes the combined electric and mechanical damping of the driver.
You look at the EBP of the driver, which is found by the Fs or the driver divided by the Qes. Roughly X<50 is more likely to be better for a sealed/4th order bandpass enclosure, x=50-100 is good for all, x>100 is better to be used in vented/6th order bandpass.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Maybe there is someone on here that has that sub that can help with the specs.
Here below are the specs of the sub, yes it doesn't look too good for a 4th BP box, it has nothing to do with cooling issues (since you can always place the motor in the front chamber so it wouldn't be too different to a ported box in that respect).
Fi btl n2 15 D1/D2
Fs: 36.6 Hz | 36.3 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.08 | 7.14
Qes: .28 | .28
Qts: .27 | .27
Mms: 270g | 275g
Sd: 810cm^2 | 810cm^2
Vas: 64.4 l | 64.4 l
Spl: 92.4dB1W/1m | 92.4dB1W/1m
Bl: 17.8 N/A | 25.1 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 2.5-5.0cuft | 2.5-5.0cuft
Sub OD: 15.625” | 15.625”
Cut ID: 14.125” | 14.125”
Mounting depth: 9.625” | 9.625”
Displacement: 0.14cuft | 0.14cuft
I could be wrong but it's my understanding that the qts determines how efficient it is in sealed/4th or 6th/ported, lower qts being ported/6th and higher qts being sealed/4th
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 5052 Guests (See full list)
