F-150 Factory radio integration?
Ok, So my buddy has a 2011 f150 XLT supercrew truck. He wants to keep his factory headunit since it has ford's SYNC.
He wants to add an amp for his highs and add an amp for 2 kicker 10s for underneath back seat.
Question is...
What is best way to add the RCAs needed for the amps? I kno he will need some sort of line output converter. But should he order 3 2channel converters or a 4 channel and a 2 channel??
Next is where to hook up the converters? right before the speaker or behind head unit?
He is trying to do this for as cheap as possible.. Please keep this in mind.
Also, if anyone knows the factory speaker ratings, that would be really helpful..
Thanks guys..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
those are quite a bit out of his budget..
I was on sonicelectronics.com and found nvx 4 channel and 2 channel converters.. i've heard great things about nvx and wonder if these will be ok..
I also need to know if i can splice the same set of speaker wires twice(once for one of the 4 channels, and once for the sub channel)?
If not, where do i splice to get the sub channel(2 channel converter)?
Thanks for the help.
1994 Ford Bronco
Sony door speakers
1994 Ford Bronco
Sony door speakers
I have also found this idea.. i was reading one of the reviews on the nvx 2 channel converter, it sed he used the NVX EQ.
It has 4 channel input and 6 channel output.. with 7 band eq.
I'd use the nvx 4 channel converter behind the head unit, run the rcas to center console where EQ would possibly b installed. Then run all channels to the amps..
How does this sound?? i like the idea of the EQ personally..
here is the eq i was looking at..
http://www.sonicelectronix.com/item_46587_NVX-XEQ7.html
1994 Ford Bronco
Sony door speakers
idatalink Maestro w/a Kenwood DD and he can retain all his Sync stuff with a good aftermarket DD.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
thats out of his price range.. how about my ideas above?
1994 Ford Bronco
Sony door speakers
Does it have the Sony system? If so then the LOC's that you want to get will not work...you need a processor that will sum the signals like the one Rob mentioned...if he is on a budget then audiocontrol is the way to go...something like LC6i....
  • Who's Online   0 Members, 0 Anonymous, 1588 Guests (See full list)
