static like crackling
flexinfusion
The preamp from the HU, powering all of your speakers, will distort early at low volumes. Your problem less within that dirty signal that the built in amp sends to the speakers.
Get an amp, some RCAs and side speaker wire and ground power, I'll bet your problem disappears.
9600hd pioneer
You need amplifier power. tweeters will stress with limited power ...
So u saying I should get a amp and run the components off that.
2009 fusion
Steeda Mods kenwood DDX418
RF T1675-s Front doors
RF T165 Rear doors
OLD SETUP:
ab XFL 1222Audiopipe 1500d
2.5cu ft 32hz
Yes sir
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Just throwing this out there, check the ground on your harness. I just recently stuck some 22 awg in the ground pocket of my harness to the radio and the noises that were happening in my car went away.
:foshizzle:
But I had my t165 2 ways in my front doors and they were sounding good uo till about a week ago when at higher volume they would crackle and now the left rear speaker does like a popish like sound when I turn my key on. U still think the amp will fix my isses or could it be that just all 4 speakers blew at the same time
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
They may be blown they might not be. But, static and distortion is going to cause them to fail over time.
oh lawd.
Is there a way for me to test to see if they are blown.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
  • Who's Online   1 Member, 0 Anonymous, 1088 Guests (See full list)
