bench Posted July 8, 2014 Report Posted July 8, 2014 Hello I am wondering how wire a kicker warhorse so I'm above 2ohm. I have dual 1.4 ohm subwoofers and was told I could wire up. Is it possible? Thanks
bbeljefe Posted July 8, 2014 Report Posted July 8, 2014 You can wire the coils and subs in series for a final load of 5.6Ω. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
martydmb Posted July 8, 2014 Report Posted July 8, 2014 Wire each sub parallel. Each sub will be .7ohm in box. Then wire outside of box series and will bring you subs to 1.4 ohm final. Or vic versa the wiring. Series in the bos then parallel outside. 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
Lbox88 Posted July 8, 2014 Report Posted July 8, 2014 Likes own post with incorrect answer... UBL | Build Log
bbeljefe Posted July 8, 2014 Report Posted July 8, 2014 LOL Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
Kyblack76 Posted July 8, 2014 Report Posted July 8, 2014 SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bench Posted July 8, 2014 Author Report Posted July 8, 2014 I was under the impression I could wire it to 2.8 ohms a side. Which I guess is the same as 5.6 total? I just dont know how that would look Thanks for the help
truthsayer Posted July 8, 2014 Report Posted July 8, 2014 If you have one subwoofer that is a dvc 1.4ohm, yes you can wire to 2.8 ohms. If you have two subs with dvc 1.4 then you can wire them both up to 5.6ohm or down to 1.4ohm truthsayer
bench Posted July 8, 2014 Author Report Posted July 8, 2014 Ya sorry I have two subs. Is there a diagram I could follow to wore them at 5.6? Thanks
truthsayer Posted July 8, 2014 Report Posted July 8, 2014 this is just an example, dont worry that it shows dvc 2ohm , wire like this and you will get the 5.6ohm load your looking for. truthsayer
