4bannger Posted July 12, 2014 Report Share Posted July 12, 2014 okay so ive been working on a few designs i wanna do a wall behind my second row seats so a "C" pillar walls. I know 4th orders have more more potential to get louder as far as spl goes. I've seen a few people run the e series subs in 4th orders but some say they are no suited for a 4th order. Would a 4th order work for the e series info- subs: 4 sundown e15's vehicle: 2004 toyota sequoia location in vehicle : behind second row, c pilar box type: walled 4th order or ported wall amp: ta1.3000d This is a design concept. Quote Link to comment Share on other sites More sharing options...
greezychef Posted July 12, 2014 Report Share Posted July 12, 2014 Please do it. Great idea. Somewhat "budget" wall. Great potential to actually slam. Sorry I couldn't offer any knowledge, just encouragement Quote Link to comment Share on other sites More sharing options...
4bannger Posted July 13, 2014 Author Report Share Posted July 13, 2014 Please do it. Great idea. Somewhat "budget" wall. Great potential to actually slam. Sorry I couldn't offer any knowledge, just encouragement Well thanks man. Hopefully some knowledgable will reply. Soon. Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted July 13, 2014 Report Share Posted July 13, 2014 I wanted to look up their T/S specs to check if they will work in a 4th but sundows page won't work right. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
4bannger Posted July 13, 2014 Author Report Share Posted July 13, 2014 I wanted to look up their T/S specs to check if they will work in a 4th but sundows page won't work right. yeah its down for me too. just goes back to the main page. what is it that make a sub a "good" sub for a 4th order. Quote Link to comment Share on other sites More sharing options...
Raptorman Posted July 13, 2014 Report Share Posted July 13, 2014 (edited) RE: 3.8ohm Fs: 29.4 hz Qes: 0.57 Qms: 6.39 Qts: 0.52 Le: 1.83mH Vas: 147.7L BL: 15.6NA Cms: 0.15MM/N Mms: 195.9grams Sens: n/a 1w/1m Xmax: 12mm one-way linear RMS: 500 watts I can't fix my font after copy/pasting that so fuck it.What makes a driver suitable for a 4th order or not is it's EBP. EBP = 1/Qes * Fs Now that you have you EBP, you know what your speaker is suitable for! If the EBP is 100 or more, it’s best for ported boxes. (And 6th order bandpass) If the EBP is 50 or less, it’s best for sealed boxes. (And 4th order bandpass) If the EBP is between 50 & 100, it will work in either style boxes. (And either style bandpass)EBP is 51.57.Will work fine for a 4th.And you should tune that a little higher. The tuning point for 4th orders differs from typical vented boxes. The tuning point is actually the low-pass point. It will be attenuating frequencies above tuning. I say tune it around 45hz. Edited July 13, 2014 by Raptorman 1 Quote 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
4bannger Posted July 14, 2014 Author Report Share Posted July 14, 2014 RE: 3.8ohm Fs: 29.4 hz Qes: 0.57 Qms: 6.39 Qts: 0.52 Le: 1.83mH Vas: 147.7L BL: 15.6NA Cms: 0.15MM/N Mms: 195.9grams Sens: n/a 1w/1m Xmax: 12mm one-way linear RMS: 500 watts[/size] I can't fix my font after copy/pasting that so fuck it. What makes a driver suitable for a 4th order or not is it's EBP. EBP = 1/Qes * Fs Now that you have you EBP, you know what your speaker is suitable for! If the EBP is 100 or more, it’s best for ported boxes. (And 6th order bandpass) If the EBP is 50 or less, it’s best for sealed boxes. (And 4th order bandpass) If the EBP is between 50 & 100, it will work in either style boxes. (And either style bandpass) EBP is 51.57. Will work fine for a 4th. And you should tune that a little higher. The tuning point for 4th orders differs from typical vented boxes. The tuning point is actually the low-pass point. It will be attenuating frequencies above tuning. I say tune it around 45hz. Which box do you think I would have better output from. I've decided I wanna go with a port above my seats so I don't have to have them folded down all the time. This is the best picture I could get of my second row seat. I would like to have the port above the seats. Would that be a good idea or would that all depend on the box type Quote Link to comment Share on other sites More sharing options...
Raptorman Posted July 14, 2014 Report Share Posted July 14, 2014 The 4th would be best for putting the port above the seats. But loading may get weird for the woofers. Can't say for sure. If you laid the woofers down horizontally. They would load a lot better. Because if you kept the woofers how they are now but had the port at the top, then the top two woofers would load into the port and the bottom two wouldn't. Quote 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
SPLadd1ct Posted July 14, 2014 Report Share Posted July 14, 2014 E-series arn't suited for 4th orders? obviously whoever says that has no CLUE what they are talking about... #1: The t/s parameters say otherwise #2: I have heard several set ups in person using them in a 4th, and they sound awesome. Quote 2011 Ford Ranger Sport 4.0 v6 2 sundown audio prototype nsv4 15s crossfire 4k wired to 0.4 ohm 15 banks of maxwell 3.0 caps @ 18v triple alts (x2 us alt 250's, x1 singer 320) 153 at 23hz Link to comment Share on other sites More sharing options...
Raptorman Posted July 14, 2014 Report Share Posted July 14, 2014 Good thing we've already covered that. Quote 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
