Inputs if this box im designing will work....
The box is for 2 Obsidian's 15V3D4s. Below are the specs for the V2s, I emailed them for the V3 specs but they haven't replied back so I just used the V2s specs. Hopefully it'll work.
Obsidian 15" v2 D2
Re: 4.0 Ohm
Fs: 31 Hz
Qms: 2.9
Qes: 0.76
Qts: 0.61
Vas: 81
Le: 4.36 mH
BL: 18.18
SPL: 87 dB
Sd: 856 cm^2
Mms: 321 g
Xmax: 20mm
Peak-to-peak: 62mm (2.45")
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 2.0 to 2.5 ft^3
Ported ~ 2.5 to 3.75 ft^3 @ 30 to 32 Hz
Cutout: 14.0"
OD: 15.5"
Mounting depth: 8"
Mounting flange to top of surround: 1.5"
Displacement: 0.19 ft^3
Here is the pic of the box design
free upload image
H=18.75 L=40 W=22
Port Length=17 H=16.5 W=3.5
Tuned to 31 Hz with a port area of 58
Any inputs will be much appreciated. Thanks!!!!!
right off the Bat that's not enough Port for 2 15s. it's prefect for one 15 but not 2.
for example a 15 sub usually likes 40-56 inches of port. so 4 4inch aero ports, 2 6s,or 1 8aero. the single 8 is what I'm running. but i haven't ran your measurements to see the size of the box yet. hold on.
7.2 cubes is a good size for 2 15s imo. i like big boxes. but i don't know your subs that well. I'm sure someone else will chime in and give a Lil more info on those subs.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Appreciate the reply bro, based on their website, 1 15 should be mated up to the equivalent of a single 6" round port which equals to 28.3 sq in. And it says do not exceed 30% of the surface area of the driver for the port. So I figured 58 sq in should be good for the 2 15s.
Like AJ said,moar port! you are gonna have an incredibly flat and low output with crazy cone noise with 8 sq inches of port per cube. 80-105 sq. Inches of port will do or 14sq.inches per cube. Your choice.
Roger that, back to the drawing board...thanks y'all
You should tell what vehicle is it and what amp you are using.
What are you max dimensions and how much power are you gonna be running??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
  • Who's Online   0 Members, 0 Anonymous, 8279 Guests (See full list)
