Best place to put voltage meter?
i was wondering where the best place is to hook up a volt meter. ive seen poeple do it in all kinds of areas, to the amp, to the alternator to the front battery, and to the rear battery. Where would be the best place to have it run to.
Imo, monitor where voltage would see the most drop. It does depend on application though.
for example I'll be running an external/adjustable regulator for my alt so I'll have one wired to my alt to watch voltage output from it and another on my rear batteries to watch voltage drop at the rear.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Depends on what you want to monitor. But generally, you want to monitor the positive at the amp.
well i had it at the amp before but i changed it to the front batt and it reads much different. I was almost thinking that the amp was stealing power from the volt meter.
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
