tju76 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Well thanks anyways guys sorry for being a pain just needed help Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 1, 2014 Report Share Posted August 1, 2014 (edited) you have the tool in your hand to find out what you need to set it at. step 1: Hook DD-1 up to the FRONT RCA output of your head unit. Use 1khz: 0db track, turn your volume up until the 1khz light stays on, then back it down until it goes off. Write this number down! step 2: Hook DD-1 up to the SUB OUT of your head unit. Use 40hz: 0db track. With sub level at 0 (or whatever the minimum setting is) turn the volume up until you see the 40hz light stay on, then back it down until it goes off. If the light doesn't stay on by the time you reach MAX unclipped volume from step 1, then start turning your SUB LEVEL up until the light stays on. If you want, and I suggest it, set the sub level somewhere a little lower than clipping level to set your amps. Write these numbers down (max volume and sub level setting)! Step 3: With your head unit set to max unclipped volume, sub level turned to appropriate level (as determined in step 2), using the 40hz: -5db OR -10db track (depends on what you listen to most), slowly turn your gain up until you get a solid 40hz light, then back it down until it goes off. Step 4: Set your head unit to max unclipped, using 1khz: 0db track, turn your gains up on your mids and highs amp until the 1khz light stays on, then back it down until it goes off. Step 5: Enjoy Edited August 1, 2014 by MrSkippyJ Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
tju76 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Only have one question when you say turn up the gain till you see the 40 Hz signal do you mean that or till I see the distortion signal Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 1, 2014 Report Share Posted August 1, 2014 Yes sorry, the distortion signal. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
tju76 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Did you mean that fir everything you said so when checking headunit etc and thank you for help Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 1, 2014 Report Share Posted August 1, 2014 Yes, everything. The 1khz and 40hz lights should light up at some point also, but that just means it is detecting a signal. The light you need to worry about is the RED distortion light. When it STAYS on is what you are looking for. Little blips can be ignored. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Noel989 Posted August 1, 2014 Report Share Posted August 1, 2014 Didn't read through the whole thread but Have you search if theirs someone close to you that has use one? Or maybe find someone to FaceTime/skype so they can see what's going on Or hit me up and I'll walk you through it Quote Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
tju76 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Okay I will let you know how it goes Quote Link to comment Share on other sites More sharing options...
Real96SS Posted August 1, 2014 Report Share Posted August 1, 2014 Do you have a manual? The unit itself isn't hard to use. Most of the time its the users fault because they fail to read all the steps or forget to make sure all crossovers are set properly. Quote Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/ Link to comment Share on other sites More sharing options...
tju76 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Okay I dis steps 1 and 2 when I go to do step three as soon as I plug in dd1 I get distortion I didn't get any distortion in step 1 and step 2 I got distortion at max volume and plus 6 level Quote Link to comment Share on other sites More sharing options...
