Call Me Dubstep Posted July 27, 2014 Report Posted July 27, 2014 My question is, are you trying to run both amps to the same subwoofer, or are your running them to different subs? 2000 Ford Focus ZX3 Mods: Raceland Coilovers Borla Exhaust Aftermarket Header System: Sony CDX-GT66UPW Pioneer 6x8's System Upgrades : Pioneer MVH-X560BT 2 sets of Rockford Fosgate P1683's Fi Audio Q 18" D2 ( Currently Own) DD M1C ( Currently Own) All SHCA Wires and stuff... XS Power 4800 ( Stock Replacement) High Ouput alternator (undecided which company or Amperage.)
bbeljefe Posted July 27, 2014 Report Posted July 27, 2014 Get the second battery grounded to the car's electrical system or get the amp's wiring off it. You can't have an amplifier that's powered from two different electrical systems. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
mikebik Posted July 27, 2014 Author Report Posted July 27, 2014 amp a is for subs amp b for speakers.... the amp's are on a distribution block from the same power source. i was using the other battery to see if it would ground but im going to find another spot to ground it.
Broke_Audio_Addict Posted July 27, 2014 Report Posted July 27, 2014 You cannot run a random battery in your trunk without it being tied into your electrical system somehow and expect it to work as a ground. You have two choices either ground the amp to the chassis or tie the rear batt in with the front batt then ground off the rear batt. The rear batt will also need to be grounded to the chassis or a run from the frront battery negative to the rear one will need to be done. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
mikebik Posted July 27, 2014 Author Report Posted July 27, 2014 So a power and ground distribution block will not work if I was to use it on the battery then run both amps on it?
Pasta Prime Posted July 29, 2014 Report Posted July 29, 2014 Your rear battery still has to be tied into the cars electrical. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
