Seqioua- MAJOR REBUILD [3 stereo integrity ht 18s 3:1 4th c-pillar wall][3 audiopipe acpl 1500.1d]
Tuned in for sure. Box is look great so far. Idk if I missed it but you running (1) TA3000.1 or (2)?
I'm only going to be running one. And if it's still not loud enough I'll go with 6 15's on 2 3k amps
Awesome. With good electrical that 3k should do pretty good.
yeah i love it so far. best budget amp ive ever had. run it at .5 ohm all the time and its never went into protect and doesnt really get to hot.
okay well didnt get anything done on the box today so i guess ill share some other things i have done to the truck. did the big three.
NOTE: its a little messy and i could have done a better job with the wire managment but it was the first time that i have ever done it and i didnt realize that planning ahead would be so important to keep the wiring clean and neat. Going to be redoing the whol thing with 2/0 wleding cable
719631E9-141E-4F4D-B27E-2C45F80A6C99_zps
081787DF-CDEA-420D-A2E5-F5AEAB2BCB13_zps
F825B261-DEA5-4F40-921D-B616DB2B01CB_zps
99FAE3FE-D136-4FE1-99DD-97309A02700E_zps
4FA4E256-199D-4F5E-8D50-7B1D7054C9A9_zps
Is that like a heat resistant braid on that 2/0 cable? Everything looks real clean and insulated. Very nice! Really like that cable. Looks like that candy paint colored Knu cable.
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
It's called Techflex, makes it look purdy.
Welding cable ftw.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Welding cable ftw.
No that's is what I did it will the 1/0 knuknoceptz kandy kable I I use techflex for the wires inside. I'm going to end up redoing it all with 2/0 welding cable so it's a little cleaner
Okay well just a small update so I can keep you guys happy with pictures I finished putting the angle brackets in all the inside corners. Think I might just wrap the whole back wall with them as well because I have like another 50 feet laying around. Just got a call from woofers etc they said they only have 3 of the four sundowns that I need so they were nice enough to give me and extra 6 months or warranty on them. Can't complain too much and I probably wouldn't be ready to install them for another two weeks while everything else it getting finished
01AF41CD-2BBD-48C7-836F-7DFF0DC3F302_zps
A9878FD1-1C49-4615-BD55-E779EC717569_zps
Okay so work has me busy as hell so I won't be getting a ton done during the week so weekends it will try to get the most done I can. Worked on more of the bracing and took and trip to the Home Depot. Decided to stop being cheap and go with threaded rod over dowels. Added the angle iron to every inside corner in the box that I could. Debating weather I should add it to the inside corners as well.
5770900C-5AF7-49AF-8241-691BF7B46764_zps
0917786B-DC26-476B-B48A-F1CD250D1926_zps
F429863B-FBC3-4C18-9F3A-80F0C5A4BE6D_zps
6CFCB560-CF77-48F3-A463-B8DED7517DD1_zps
141991F7-A4D2-47C1-BF07-98BD59B79662_zps
FBE2C13A-87D6-4D8F-B924-965D0FA0C069_zps
7C60E595-9DF8-4D8B-A61F-4E83FF7C2DB7_zps
Looks good, on a side note, Loctite PL 3x will blow that powergrab out of the water. Not that it's bad, it will work, but you should definitely go with the PL 3x from now on. It's a lot stronger!
Good work so far though, looking good.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   2 Members, 0 Anonymous, 569 Guests (See full list)
