just makin sure before i cut out the wholes...on dc sound labs website... it says this
10" 12" 15" 18"
Mounting Depth 6.25" 6.75" 8" 9"
Mounting Hole Diameter 9.25" 11" 14" 16.75"
Motor Width 7.75" 7.75" 7.75" 7.75"
Weight 31.5lbs 32.5lbs 33lbs 35.5lbs
VC Diameter 3" 3" 3" 3"
Magnet Weight 28.5lbs 28.5lbs 28.5lbs 28.5lbs
Power Handling RMS/Peak 1000/2000 1000/2000 1000/2000 1000/2000
Impedance D 2ohm D 2ohm D 2ohm D 2ohm
Sd 314.00 cm² 494.00 cm² 791.00 cm² 1159.00 cm²
Vas 27.40 L 66.60 L 160.00 L 260.90 L
Cms 1.99e-04 m/N 1.95e-04 m/N 1.83e-04 m/N 1.39e-04 m/N
Mms 115.70 g 173.08 g 211.60 g 218.61 g
Fs 33.2 Hz 27.4 Hz 25.6 Hz 28.9 Hz
Bl 16.15 N/A 16.15 N/A 16.15 N/A 16.15 N/A
Re 3.60 ohm 3.60 ohm 3.60 ohm 3.60 ohm
Le 4.02 mH 4.02 mH 4.02 mH 4.02 mH
Qms 5.15 5.13 6.07 6.55
Qes 0.43 0.42 0.47 0.70
Qts 0.40 0.39 0.44 0.63
Xmax 23.5 mm 23.5 mm 23.5 mm 23.5 mm
Sensitivity 85.50 dB 87.0 dB 89.4 dB 91.4 dB
Suggested Sealed N/A N/A N/A N/A
Suggested Ported 1³ ft 1.5³ ft 3³ ft 5.75³ ft
Suggested SPL Ported 1.25³ ft 2³ ft 4³ ft 8³ ft
for the 15" the mounting whole that has to be cut is 14 in right?? just wanna make sure, k thx
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
looks rite to me 14 inches for the cutout
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
yup
ok and thanks david for the constructive critisim yesterday, was just havin a bad day... idk why but the whole box breakin pissed me off....but its all better now..:) ill have pix up tuesday, just got the ups conformation that my subs will b here tuesday
and the shipping weight got me all happy....74lbs...:D
My F-150 Build
not all frames are the same... most Cast Alum frames require from 14"-14.25" cut out, depending on the frame type
If you have a jasper jig, and it says 14", I would do about 14 1/16th- 14" 1/8"
I really hate cutting a PERFECT 14" ID hole for a 15, and then ya gotta bang the woofer in place
yea im kinda nervous about cutting the hole before i have the woofers..... but i gotta cut it so i can wrap in carpet tommorro..and it has to be all ready cause i gotta pick som1 up at sac airport at 12:40...and my subs should be here at around 11:30...i wanna slap all the way there to give them a good break in, lol
My F-150 Build
