step down transformer build help
looking to step down the 12 volt out from the cig lighter to 5-7 volts so that the device I want to connect doesn't fry.
Any help on how to accomplish this would be greatly appreciated.
Thanks.
Rolex you sicken me.
Just let me finish my pie
~ Juice
I think you will need something called a 5v regulator. You can look up a circuit design online most likely.
Then you could get one of these and wire it up http://www.ebay.com/itm/12v-Male-Car-Cigarette-Lighter-Socket-Plug-With-Fuse-Connector-Conversion-Outlet-/331079406572?pt=US_Adapters&hash=item4d15ded3ec
Hope I helped, I've never built anything like this but I have watched a few videos online about building electronics.
Pioneer DEH-X6600BT
(1) Rockford Fosgate R1200-1D
(1) Alpine 1242D 12" Type R ported 32-35hz
Thanks guys. I was overthinking this and looking to build a circuit. Instead I found a couple schematics on making one and after I buy the parts and put the time in it's cheaper just to buy a pre fab one. If I was making more than 5 then it would be worth it. I may also just go through my junk cell phone charger drawer and see if any of those spit out 5-6 volts dc :)
~ Juice
all you need is a 7805. look that bad boy up.
whats your load? depending on the load you may or may not need a heat sink
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • 3 months later...
As stated a 7805 was all I needed. here's the down and dirty in pics.
Made for less than $5 and built my way. 9-20 volts in with a constant 5 volts out!
WP_20141006_23_04_17_Pro__highres_zpsac5
BTW, the 1st pic was parts I cannibalized from an old VCR. I ended up buying new parts but the VCR parts would have been fine.
This will do 2 amps max with the heat sink
~ Juice
looks good man! a lot of devices run on 5 volts dc.
BMW M340 xDrive
