loganberry Posted March 24, 2008 Author Report Share Posted March 24, 2008 kind of gay to rate it >900 at 1 ohm. why cant they give an actual rating? it does more then 900 at 1 ohm, the one i have is doin 1200 at 2 ohm, 1400 at 1 ohm...maybe thats not the sameo ne... Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
subnoize Posted March 24, 2008 Report Share Posted March 24, 2008 (edited) ya the reg ken woods are not that great but the excelons are better thats what i am running it the x10d. have you checked the remote turn on aka blue wire does it do it during a bass note or wile driving could be it hanging by a thread. that or the rca are going bad Edited March 24, 2008 by subnoize Quote Link to comment Share on other sites More sharing options...
loganberry Posted March 24, 2008 Author Report Share Posted March 24, 2008 ya the reg ken woods are not that great but the excelons are better thats what i am running it the x10d. have you checked the remote turn on aka blue wire does it do it during a bass note or wile driving could be it hanging by a thread. that or the rca are going bad it only does it when im bangin hard....i can have the voulume low and it does it, but after a much longer time...i think the remote is fine but ill check it...and like i said the rcas are rockford and have not gave me issues before Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
subnoize Posted March 24, 2008 Report Share Posted March 24, 2008 it only does it when im bangin hard....i can have the voulume low and it does it, but after a much longer time...i think the remote is fine but ill check it...and like i said the rcas are rockford and have not gave me issues before mite4 be a thermal issue were the thermal protect is tripping i have done this by criss crossing the wires because of a screw screwed threw them so check every were speaker wire is ran too Quote Link to comment Share on other sites More sharing options...
loganberry Posted March 24, 2008 Author Report Share Posted March 24, 2008 mite4 be a thermal issue were the thermal protect is tripping i have done this by criss crossing the wires because of a screw screwed threw them so check every were speaker wire is ran too it goes in 2 places, the sub box, and the amp...it has two terminals to be hooked to on the amp, even tho its only a mono..it has a set up like 2 channel, should i just hook it to one side? or like 1 post, and the other neg...idk i have it set up now, but i could try the other way Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
ChevyBoy Posted March 24, 2008 Report Share Posted March 24, 2008 sorry kenwood sucks thats why they are sold at best buy. so rockford sucks cause its sold at best buy and kicker/infinity/eclipse suck because theyre sold at circuit city??? i dont think so. it only does it when im bangin hard....i can have the voulume low and it does it, but after a much longer time...i think the remote is fine but ill check it...and like i said the rcas are rockford and have not gave me issues before what coogle said was check the rca voltage. your head unit puts out a certain voltage though the rca's. its not that theyre faulty, but the voltage from the head unit might be higher than that amp typically accepts. find out what your preout voltage is on your head unit, and find out what the input is on your amp. Quote Link to comment Share on other sites More sharing options...
subnoize Posted March 24, 2008 Report Share Posted March 24, 2008 it goes in 2 places, the sub box, and the amp...it has two terminals to be hooked to on the amp, even tho its only a mono..it has a set up like 2 channel, should i just hook it to one side? or like 1 post, and the other neg...idk i have it set up now, but i could try the other way you do not bride these. run it off one one plus one minus i use the far left plus and far left minus and it does not hit loud so i switch them to the right plus and right minus if you catch what i am saying plus and minus go in pairs just paly with it it more then likely the problem Quote Link to comment Share on other sites More sharing options...
loganberry Posted March 24, 2008 Author Report Share Posted March 24, 2008 ok will do, thanks Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted March 24, 2008 Report Share Posted March 24, 2008 (edited) It's the amp. Just don't push it so hard until you can replace it with a more overbuilt amp. The kac 9152D is rated at 500rms @ 4ohm, 900rms @ 2ohm, and NOT reccommended for 1ohm use at all. I would say it's only 4ohm usable if ur gonna push it hard...but 4ohm aint really pushin it hard by "most" folks standards..mine included. It's just a cheap amp...it's not meant for competition use or evan hard labor like a RF/Kicker/Sundown/etc. Just look into a more overbuilt amp, and maybe sell the oen you have to help pay for the upgrade. It's a fine amp for an easy listening or SQish daily, just not really capable of even running 2ohm very long w/ out going into protect. Check out some reviews on it they're pretty much all the same..protect issues. edit* It's a monoblock...how is any of the previous info/recommendation gonna change anything? The AMP doesn't care if you use both +'s and -'s or not... it's a mono block amp. Edited March 24, 2008 by LSN2meBoom916 Quote COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
loganberry Posted March 24, 2008 Author Report Share Posted March 24, 2008 It's the amp.Just don't push it so hard until you can replace it with a more overbuilt amp. The kac 9152D is rated at 500rms @ 4ohm, 900rms @ 2ohm, and NOT reccommended for 1ohm use at all. I would say it's only 4ohm usable if ur gonna push it hard...but 4ohm aint really pushin it hard by "most" folks standards..mine included. It's just a cheap amp...it's not meant for competition use or evan hard labor like a RF/Kicker/Sundown/etc. Just look into a more overbuilt amp, and maybe sell the oen you have to help pay for the upgrade. It's a fine amp for an easy listening or SQish daily, just not really capable of even running 2ohm very long w/ out going into protect. Check out some reviews on it they're pretty much all the same..protect issues. ok, guess ill just have to stick with this it for a while till i can get my other stuff Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
