rf components ideal amp
flexinfusion
So to wire up each cross over just run the speaker wire from the amp to which input on the cross over. Because I have a woofer input and a tweeter input.
2009 fusion
Steeda Mods kenwood DDX418
RF T1675-s Front doors
RF T165 Rear doors
OLD SETUP:
ab XFL 1222Audiopipe 1500d
2.5cu ft 32hz
Oh shit maybe I lied then, sorry about that. If they have separate inputs then you'll want a 4 channel the pair.
The X-overs can be bi-wired. This would give each individual driver (2x tweets & 2x mid-woofers) their own channel of amplification.
That being said they can still run off of a 2-channel amp as long as there are jumpers placed between the woofer inputs and tweeter inputs.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
Jumpers as in from cross over to cross over.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
My cross over has a bi amp switch on it
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
No, from woofer + to tweeter+ and from woofer - to tweeter -. The amp would connect to the + and - of either the woofer or tweeter. Since they are jumpered together it doesn’t matter which.
If there's a switch the X-over may not need the jumpers. Check the manual.
you could use a 2 or 4 channel. If you are using two channel then use the tweeter output on the crossover.
Here's a link to the manual to help:
http://www.rockfordfosgate.com/support/rftech.aspx?kbsrc=http://rftech.custhelp.com/cgi-bin/rftech.cfg/php/enduser/std_adp.php?p_faqid=1062&p_li=&p_topview=1#knowledge
Did you bother to read the manual? RF his a simple diagram in the manual for the speakers. Or at least for all the RF speakers I've had.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1013 Guests (See full list)
