Nadeem Posted March 24, 2008 Report Share Posted March 24, 2008 Is there anyone here who has bypassed the n3? i have been searching but can't find a valid source. I have tried putting switches. I have 1 for the speed sense and 1 for the parking brake. the problem is that if i have a video running, and i have the parking brake grounded, it will cut off because it still detects the car is moving(Speed Sense). I have to Bypass the speed sense with out it disturbing my speedo. I can't even use my nav because i have to have my speedsense running with the parking brake grounded. It ends up loosing itself when the brakes grounded. I want to try to avoid ripping some sticker from the back to gert my warranty viod. If anyone has any info on this, please share. Thanks Link to comment Share on other sites More sharing options...
Ray Posted March 24, 2008 Report Share Posted March 24, 2008 you have to peel the sticker. it just a switch on the other side. go here. avic411.com 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
Torres Posted March 25, 2008 Report Share Posted March 25, 2008 if it's the soldering process...be careful. it will void the warranty Link to comment Share on other sites More sharing options...
251customs Posted March 25, 2008 Report Share Posted March 25, 2008 only way ive seen it done is the sticker thing its just a switch 02 dodge ram quad cab 4.7 pioneer 9800bt pioneer 5700 dvd(yes 2 headunits 5700 for dvd only) 1 re xxx 15 (new style in center console) 4 18" fi btls in snugtop 12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door) quart 4" dash sp 2 soundstream xxx6500s 1 pd asa1000.1 for the xxx15 4 pb asa600.4 highs 4 7" screens 1 15" flipdown 2 red tops 16 g31 yellow tops playstation 2 4 8x11 p.a. horns under truck (music plays through them) db 80.2 for horns 2 underglow kits (1 flex kit in fenderwells) 24" martin bros vampires Link to comment Share on other sites More sharing options...
ChevyBoy Posted March 25, 2008 Report Share Posted March 25, 2008 you DONT have to remove the sticker. ive done this before on mine. its on avic411.com.......lemme find it...... here http://www.avic411.com/forum/viewtopic.php...t=avicn3+bypass its really not that hard. just push that switch over and ground the e-brake. Link to comment Share on other sites More sharing options...
Deafdreamz Posted March 29, 2008 Report Share Posted March 29, 2008 you DONT have to remove the sticker. ive done this before on mine. its on avic411.com.......lemme find it......here http://www.avic411.com/forum/viewtopic.php...t=avicn3+bypass its really not that hard. just push that switch over and ground the e-brake. They way i did it is ground the pbrake and move the mute wire up a pin and ground it too. (If i remember right) http://www.avic411.com/forum/viewtopic.php?t=4670 Car-96 blazer 4 door Amp- Us-Amps M2D2 Front stage- Infinity Reference Comps 6.5 Subs- Undecided open to all offers and opinions You had to have it all Have you had enough You greedy little bastard You get what deserved When all is said and done I will be the one To leave you in your misery and hate what you have become Link to comment Share on other sites More sharing options...
ChevyBoy Posted March 31, 2008 Report Share Posted March 31, 2008 They way i did it is ground the pbrake and move the mute wire up a pin and ground it too. (If i remember right)http://www.avic411.com/forum/viewtopic.php?t=4670 this was for the n3 not the d3 Link to comment Share on other sites More sharing options...
