TRON Posted August 9, 2014 Report Posted August 9, 2014 All the power to you, but remember, you're stretching it so damn far it will probably crack, at least that what always happened to me when I tried it. edit: If it takes you more than an hour, then its better to buy the $7 ports because I'm guessing you make more than $7 an hour. Took me all of 2 min to do them flares Fuck, I dicked around with a heat gun and a cereal bowl for 30 mins just to get it half bent. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
sbg Posted August 9, 2014 Author Report Posted August 9, 2014 All the power to you, but remember, you're stretching it so damn far it will probably crack, at least that what always happened to me when I tried it. edit: If it takes you more than an hour, then its better to buy the $7 ports because I'm guessing you make more than $7 an hour. Took me all of 2 min to do them flares Fuck, I dicked around with a heat gun and a cereal bowl for 30 mins just to get it half bent. This was my first time and no joke. 2 min on each port. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted August 9, 2014 Author Report Posted August 9, 2014 All the power to you, but remember, you're stretching it so damn far it will probably crack, at least that what always happened to me when I tried it. edit: If it takes you more than an hour, then its better to buy the $7 ports because I'm guessing you make more than $7 an hour. Took me all of 2 min to do them flares Fuck, I dicked around with a heat gun and a cereal bowl for 30 mins just to get it half bent.This was my first time and no joke. 2 min on each port. To be fair, I did step on the heat gun with my bear foot after the 2nd port lol. It hurt so bad! 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
TRON Posted August 9, 2014 Report Posted August 9, 2014 To be fair, I was using ABS pipe the first time... Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
sbg Posted August 9, 2014 Author Report Posted August 9, 2014 To be fair, I was using ABS pipe the first time... I don't even know what that is, I just got mine of the home depot self lol 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted August 9, 2014 Author Report Posted August 9, 2014 So do I even need to flare both sides? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
TRON Posted August 9, 2014 Report Posted August 9, 2014 ABS is like PVC, but a lot tougher. It's also black, where PVC is white. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
OrionStang Posted August 9, 2014 Report Posted August 9, 2014 Didn't read all the back and forth, but the PSP kits use a larger flare on the outside, smaller on the inside. SMD Super Seller My Feedback Thread
sbg Posted August 9, 2014 Author Report Posted August 9, 2014 ABS is like PVC, but a lot tougher. It's also black, where PVC is white. Black / white ... Plasti dip can make it whatever. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
poorfish88 Posted August 9, 2014 Report Posted August 9, 2014 You could flair the inside of the pipe ,and router the wood baffle for the outside flair.
