Ported vs sealed
Jchristian30
I'm wanting to build a new subwoofer encloser for 2 10s. I want to reach the max output of them but don't have a lot of space. So the question is. I can either build my box to the max sealed or .3 cubes bigger than the min. Ported. What would be the best??
Abstract questions lead to bad answers, post the max dims of for a box you have, the vehicle model and the model of the subs.
55" long 14" tall top depth is 5" and bottom is 8.5
I have 2 pioneer ts-w254r. If I go ported I'm using aero ports. Outside the box. After displacement of subs I got around 2 cubic feet and for ported they require atleast 1.8 cubes
i'd put them in a sealed enclosure right at .9 cu. ft. per sub, and give them a descent amount of polyfill. power them at around 275 watts rms. under the seats even! what kind of music do you listen to most? when space really isn't an option, a small sealed box with descent rated power for the subs should work well. in my opinion.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
You can't fit an enclosure under The seat of a regular cab Chevy/GMC full-size, I own one.
JChristian, build a sealed box with the cut out for the center console to fold down. Until you're ready to remove the center console and get a real box for a couple of ported 10s or 12s, that's your only option.
You can do a box for a single beast 10" sub, ported with a round or aero port to the passenger B-pillar. This enclosure type sounds the best and loudest in our trucks.
  • Who's Online   0 Members, 0 Anonymous, 9449 Guests (See full list)
